finally, it runs!
I cant wait to drive this thing. only a handfull of minor things left till I can drive it. anyone around here know how to put a short vid. on the net? when I fin. the exh. Id like to get some video of it on here. almost time to update the sig. here's what I did the winter/spring
233/239 .580 cam
1.6 roller rockers
ported heads and intake (by myself thank you
swapped the 3:73 rear out of the iroc behind the 95 (yes, the Iroc had a 4 gen axle)
jet hot longtubes/ypipe
edelbrock rpm catback (still need some tips though)
boxed lower rear control arms
24mm Iroc rear swaybar
flamed dash overlays
powdercoated intake/polished rails
soon to have MadZ28 tune
30lb svo's
walbro high press. fuel pump
tayler OTVC wires
this should be a much funner car then prev. w/it best prev. time of 13.8 on drag radials at milan.
chris
233/239 .580 cam
1.6 roller rockers
)swapped the 3:73 rear out of the iroc behind the 95 (yes, the Iroc had a 4 gen axle)
30lb svo's
tayler OTVC wires
chris
Hey Chris, I can help you out with the video. upload it here
http://stavos.homeip.net/detroitarch...loadCenter.asp
any problems email me stavos@detroitarchive.com
well, sorta. its still attached to the eng. from the Iroc, however the eng/trans is tucked away in the gar. till one day when I get the Iroc taken apart, painted, and then reassembled. who knows when that will be. after I have the 95 straghtened out, I have a couple other projects that need to get done. then I can start tearing the Iroc apart again to get it ready for paint/rollcage.
ChrisFrez
Dec 7, 2014 06:01 PM
squarehead
Nov 21, 2014 08:02 PM
guionM
14
Jun 19, 2002 08:30 AM
