engine horsepower?
kandied91z wrote on 09-06-2003 08:37 PM:
here is one of the setups
gm 383 4 bolt main.
fastburn aluminum heads with 1.5 rockers
tpis zz-409 cam
tpis miniramIII
30lb injectors
700-r4
2800 stall
3.23 rear
gm 383 4 bolt main.
tpis zz-409 cam
tpis miniramIII
30lb injectors
700-r4
2800 stall
3.23 rear
Either way, I'll take a guess just for the hell of it. I'd say that setup would be close to 430~440hp @ the crank...360~370hp @ the wheels. I wouldn't be surprised if I'm off though.
Originally posted by TreySpeed
head flow charactoristics
the compression is only 9.7.1 right now...the rod length is standard and i'm not sure on the timing right now. regardless i need to find someone who knows a thing or two as tpis really screwed up on some parts unfortunately.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 29, 2015 07:10 PM
CARiD
Jan 27, 2015 06:27 AM
You said somewhere else that the heads were worked also. Only you know how much. There could be 20-60hp in a correctly placed head massage.
