does anybody know how to install a boost gauge
Does anybody in the area know how to install a boost gauge. I have the faze style gauges. It's currently hooked up but not to the boost just to vac. I was wondering where to connect the wires to what to see the boost. Any help would be great. - Mike
Re: does anybody know how to install a boost gauge
The vac side is working but the boost does not work at all. Last year when I had the gauges installed the guy said he hooked up the gauge for the vac. This year I had a turbo put on. Should the gauge be reading the boost when it comes on then? Dont I have to connect a wire or something to the turbo??
i'll look into that gauge
is this the one you have?
http://www.fazegauge.com/prod_gauges...ducts#products
is the gauge mechanical or elec.? if its mechanical, it should be reading both vac. at idle/low rpm, and boost when you get into it. if its elec. and there's a sender, the sender or gauge itself could be bad or not hooked up properly.
Why go through the hassle to put it in the intake piping? I had mine Tee'd into a factory vaccum hose coming right off the intake manifold. Very simple to do really.
99TransAmWS6
Feb 12, 2015 07:23 PM
Antz97ZNJ
48
Jun 20, 2002 06:09 PM
