Custom brake lines...
Putting the finishing touches on the Areospace brake install and
want/need to have some custom lines made.
Anyone reccomend any places in the Wayne County area?
TIA
Kevin
TIA
Kevin
Jim,
Tried a couple local places to have a set made ...no luck.
I have some 24" 3AN lines I can use but 18"s
would work better, do you know where I can get 18" 3AN hoses
quick?
Kevin
quick?
Kevin
Kevin,
I know Scamchargers carries -AN line, not sure about -3 though. Do you need it already with fittings? Cause if not then you can cut your own length, and the fittings just screw right on.
edit: Also, while never having done it before, cutting it shouldn't be that hard if you can find something sharp enough with enough leverage. I guess the trick is to wrap the area in tape so that it doesn't unravel when cut.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
