Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Coolant Leak
Old Mar 8, 2006 | 05:31 PM
hemigtx001's Avatar
Coolant Leak
im leaking coolant. i think i figured out where its leaking from.
its on the outside of the radiator.
so it look slike i need a new one. unless this is fixible.
or someone can give me a second opinion as tow here its leaking from.
IF it needs to be replaced. does anyone have a v6 3.4L radiator laying around?
Old Mar 8, 2006 | 06:28 PM
96flame's Avatar
Re: Coolant Leak
Is it the tank to core seal thats leaking?? If you know its the rad for sure you could take it out and have a rad shop look at it. They will give you an estimate and then you can decide to fix or replace.
Old Mar 8, 2006 | 08:11 PM
IrocSS85's Avatar
Re: Coolant Leak
oh damn, I forgot all about this john. sorry. if I were you I'd just look for an LT1 or LS1 rad. to put in there. you should be able to find one of those really easily. your hoses are universal fit, so they should go right onto a diff. radiator as long as the reach is close.
Old Mar 8, 2006 | 10:01 PM
hemigtx001's Avatar
Re: Coolant Leak
thats true chris i should look for a bigger radiator. but the thing is the lt1 has like 2 extra holes that i dont need. i just need the simple in and out and the trans hookup.
ill pull it this week sometime and take it in. its the tank area on the radiator. maybe a corvette radiator will fit in there?
Old Mar 8, 2006 | 10:17 PM
IrocSS85's Avatar
Re: Coolant Leak
a 3rd gen rad. would fit Im almost positive. if you want to go with me out to dundee I can let you borrow mine to test the fit. hell, even borrow it for a while till you find your own. a c4 vette rad. would prolly fit right in, and I think I can get a new one for under $200 if I remember right and they havent changed the price.
Old Mar 9, 2006 | 07:06 AM
hemigtx001's Avatar
Re: Coolant Leak
that sounds good to me chris. as long as its the radiator. i want to try to make opening day still and i cant break in an engine without a cooling system.
gimme a call. im free this weekend. and tonight and tomoro night. i know you usually work late tonight.
ill talk to you later.
Old Mar 9, 2006 | 11:21 AM
jp2002ls1's Avatar
Re: Coolant Leak
Hey Jon, how is it running? You can start to tune it up now that the temperature is above 20 degrees. Let me know when you go to the track.
Old Mar 9, 2006 | 04:38 PM
hemigtx001's Avatar
Re: Coolant Leak
if all goes well. lol i should be going on the 1st.
Ive tuned it when it was 50 degrees a bit. but i had to retune it when it dropped back down to 20. i love michigan.
Old Mar 9, 2006 | 06:48 PM
IrocSS85's Avatar
Re: Coolant Leak
john W, I'll be home tomorrow workin in the garage if you want to come over and we'll figure it out. I have a pressure tester at work I'll bring home. but you know you gotta call me to remind me to grab it. you can check out the new crib too.
JP, how was the fights? I wish it was on a diff. night then sat. night every time. even fri. would be better then sat.. didnt shamrock fight? I forget who the big fight was goin to be.
Old Mar 9, 2006 | 07:02 PM
hemigtx001's Avatar
Re: Coolant Leak
hey you want me to bring the car by? or the radiator?
it usually stops leaking once i stop idling in park.
Old Mar 9, 2006 | 07:30 PM
IrocSS85's Avatar
Re: Coolant Leak
bring the car
blac94Z
Feb 15, 2021 09:43 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Blood type Z28
Apr 8, 2015 11:34 PM
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
dansam
Jul 20, 2002 01:10 PM
