Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Can Someone Help Up My Rev Limiter And Shift Points
Old May 17, 2003 | 11:01 AM
Bill'sWS6's Avatar
I need to change my shift points before I go back to the track next time. They are set at 6000 and need to bumped to 6500 Does anyone have anything that can do this without screwing with my programming? I will make it worth someones time and effort.
Thanks,
Old May 17, 2003 | 02:31 PM
charliediss's Avatar
Whenever I need computer work done, I bring my comp to Troy Brown, He works for Howell Engine developements, they do alot of work for IRL, Cart, but Troy ONLY programs GM computers, and he really does a great job. His number is 1-313-724-0817. If you decide to go this route, tell him Charlie sent you, and he will hook you up really good. He could either adjust your shift points/rev. limiter, or he could write you a completely new program that will wake your car right up. The program would very in accordance to what you have done to your car. This really is the closest you can get to a dyno tune. This guy is great, and his prices are good too. The best part is, if you are not satisfied, you can send it back and he will fix whatever you are not satisfied with. I could be a middle man if you want, I live close to Howell, so if you want to send me your comp, what you want done, I would be happy to take care of it for you. I will also get you a written invoice stating everything that has been done. Call me at 1-586-531-8932, my name is Charlie.
Good luck.
Charlie
Old May 17, 2003 | 10:02 PM
Bill'sWS6's Avatar
Thanks for the offer Charlie........ I was really needing to take it some place to get the shift points done while I wait. I plan on going back to the track this Thursday. So, I don't think that would work if I sent you my computer.
I will keep it in mind....... Thanks for the offer.
Bill
HarleyZ28
Oct 5, 2015 06:23 AM
cristian1311
Apr 22, 2015 10:20 PM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Rbain
Sep 4, 2002 12:35 PM
