Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
C5 Corvette wheels and tires, local to New Baltimore, MI ONLY
Old 05-25-2008, 11:24 PM
fryguy's Avatar
03 Corvette stock wheels and tires, great shape and low milage. $650, will not ship, local only.
Click here for pics:
http://detroitracing.net/forums/showthread.php?t=6111
fryguy is offline
Old 05-26-2008, 08:01 AM
Black Sunshine/ 00SS's Avatar
Will these fit a 2000 Z28? Are they 17, or 19? What size are the tires.
Black Sunshine/ 00SS is offline
Old 05-26-2008, 09:31 AM
jp2002ls1's Avatar
They will fit a 2000 Z28 but have a slightly different offest than stock. The fronts should be 17x8.5 and the rears should be 18x9.5.
jp2002ls1 is offline
Old 05-26-2008, 01:28 PM
So, they are 17's, or 18's? With the offset being different, will they rub, or stick out?
Old 05-26-2008, 04:16 PM
jp2002ls1's Avatar
If they are stock the the difference in offset will cause them to stick inward slightly and may rub on the inner fenderwells in the back, most people run a 1/4" spacer to correct the offset. The front 2 rims are 17" and the rear 2 rims are 18".
Old 05-31-2008, 05:25 AM
fryguy's Avatar
They look great on an F-body. I was going to use these but I ended up going with a narrowed 9" and drag wheels.
fryguy is offline
carguy0119
04-11-2016 11:11 PM
dpw21562
01-23-2015 04:58 PM
globalprojeff
12-06-2014 04:18 PM
globalprojeff
Wheels and Tires
12-06-2014 04:09 PM
Hoodshaker
08-27-2002 02:32 PM
Quick Reply: C5 Corvette wheels and tires, local to New Baltimore, MI ONLY
