Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Anyone got a scrap LT1 aluminum head lying around?
Old Feb 28, 2007 | 06:31 PM
  #16
97 6SPEED Z's Avatar
Thumbs up
Originally Posted by Hot Rod Hawk
ya I know nothing about putting together a 8.9 to 1 DRC LT1 combo
if it were "me" I'd run it .002~.003 in the hole and use custom head gaskets with a bore dia .005 larger than the actual bore dia of the block.
good luck on the LT1 chambers there not than beefy for what your wanting to do.
Irocss makes a good point about a slight shift in camshaft too bring the drc into your target . gaskets and camshaft are your savings grace, not chamber tweeking on a LT1 casting
Hot Rod Hawk...... I know how that goes........after 41 years of drag racing with numereous SBC cars...........ya, I guess I know nothing about putting together a 9.0 to 1 DRC LT1 stroker combo..........either
Chris......thanks for your comments also.
Now, anyone local got that dusty LT1 head just proping open a door somewhere?
Old Mar 1, 2007 | 02:30 PM
  #17
Thumbs up
Hot Rod Hawk, please don't take this the wrong way as I truly appreciate your trying to help me "brainstorm" my way through this, but....... touching up the piston valve reliefs affects the balance of the rotating assembly, (as I'm sure you know), but it also affects the fatigue life of the piston, an order of magnitude more, that thinning out the chambers would. Plus, and you'll have to trust me on this, there is much to gain by reconfiguring the chambers. Thanks to all who replied!
Old Mar 1, 2007 | 02:51 PM
  #18
IrocSS85's Avatar
well then take pics of what youve done and post them. just curious to see how you reshape them.
Old Mar 1, 2007 | 07:00 PM
  #19
383TransAm's Avatar
Did you find a head?
Old Mar 2, 2007 | 01:46 PM
  #20
Smile
383TransAm, in a word.......nope.....still looking for that trashed LT1 head I can save from the dumpster.
Old Mar 2, 2007 | 02:30 PM
  #21
383TransAm's Avatar
Where are you located?
I have one you can have
I ripped the Rocker stud boss out of it and had it welded.
It's from a 93 LT-1.
Old Mar 2, 2007 | 02:57 PM
  #22
Thumbs up
I'm in Washington, MI about 30 miles north of Detroit. Anything ever bring you to the metropolitan Detroit area??? Autorama, SAE, visiting friends/relatives etc.?
I know you said this head is off of an '93 LT1.... are the last three digits of the casting number 561 (i.e. GM P/N 12551561)? Some early LT1 heads are a different casting altogether.
Old Mar 2, 2007 | 05:42 PM
  #23
383TransAm's Avatar
I would have to look.
I'm going to MIS in Aug. & I will be in Linwood in May Walleye fishing
Old Mar 3, 2007 | 11:11 AM
  #24
Thumbs up
383TransAm, when you get some time please check the part number on the head you're willing to give away, and if it's 12551561 do let me know. And thanks for your offer!
Old Mar 3, 2007 | 03:33 PM
  #25
383TransAm's Avatar
The castin # on the top where the rockers go is: 10207843
Thge other # is 6054
Old Mar 4, 2007 | 01:30 PM
  #26
Smile
383......Thanks! sooooooo much for your offer, but, as I suspected, your cylinder head is the early "thick wall" casting, and, while prized by head porters everywhere, does me no good. I need to cut up a 561 casting head to get the info I want. Thanks again for your kind offer, and, of course, Good Luck with your car.
*Emilia*
May 13, 2015 09:05 AM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Brandon Wittmer
Dec 7, 2014 12:15 PM
