Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
any mechanics do side work
Old Nov 20, 2005 | 11:32 AM
badasschevy625's Avatar
i have a 99 malbu and its fricken sqeaking not the belt some pully and the pullys dont line up need to get it fixed and i dont have time anyone intrested im in the plymouth canton area would like it to be pretty close
Old Nov 20, 2005 | 12:07 PM
Brett H's Avatar
Re: any mechanics do side work
I would guess its the idler pulley that has taken a dump, a common problem with GM.
Old Nov 20, 2005 | 01:08 PM
raroz28's Avatar
my neighbor had a problem. I was helping him with it for a bit... I kept thinking it was a belt or pulley. He kept messing with that...
Ended up being the intake gasket leaking causing squealing. Gives a belt/pulley sound though.
Old Nov 20, 2005 | 08:20 PM
Dave89IROC's Avatar
There are a few around here, I could look at it too, let me know if you can bring it over here(just south of Detroit)
Old Nov 20, 2005 | 10:18 PM
IrocSS85's Avatar
I know this will sound funny, but check the pcv valve. sometimes people will change the pcv valve and the oring will come out with the orig., and not get put back in. resulting in a huge vacuum leak into the crankcase. and it willsuck air into the eng. usually through the oil pan seal (or any gasket for that matter) squeeling really badly. an easy way to check this is while its making the noise, take the oil filler cap off. if thats it the car will almost stall, and you'll be able to hear/feel the air being sucked into the valvecover through the filler neck.
you could always bring it to my work at bob sellers pontiac gmc in farmington hills if you cant find anyone close enough to you. Id do it at home, but I now live in waterford, not exactly close to you.
Old Nov 22, 2005 | 12:05 AM
jp2002ls1's Avatar
If its the 3.1 V6 then my bet is on the leaking intake gasket. I replaced one on my friends Malibu 2 months ago and I was suprised that it was the intake and not a bad pulley.
Old Nov 23, 2005 | 09:54 AM
Mean Green's Avatar
if you say the pulleys don't line up, the belt was probably puttin extra side force on one of the pulleys and caused a bearing to go bad. i'd suspect the idler pulley on the tensioner to be the first to go, but the alternator pulley bearing is also a weak point. if they're bad you can usually just tell by listening closely to it.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Jazsun
Dec 29, 2014 12:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
