Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
94 Trans Am freek car?
Old Jun 24, 2003 | 12:12 AM
mavricki18's Avatar
my buddy has a 94 Trans Am and is the 5th owner. His mods consist of SLP CAI and no cat, he took it to the track an ran a 13.771. Is this normal for an LT1 or is it likely that a prevous owner put a cam or a gear in it?
Old Jun 24, 2003 | 12:17 AM
Timberwolf's Avatar
Re: 94 Trans Am freek car?
Well, my 94 with a CAI and no cat or muffler ran 13.21... of course I pulled some weight but if you assume a tenth for every 100lbs... that would still put me at a 13.4 or so with stock weight... I do have 3.73 gears. so that helps the 60' a bit when I could get traction...I am guessing the T/A has either the optional gears for the a4 or stock m6 gears depending on his equipment. If he does have a 3.73 that might explain a little more...
Old Jun 24, 2003 | 12:29 AM
mavricki18's Avatar
I see makes a little more sence now
13.2 with a pretty much stock lt1 sounds good props to you
Old Jun 24, 2003 | 09:24 AM
ltlhomer's Avatar
My car went 14.3 @ 98 with k/n cai and !cat but it had crappy 2.73's and 2.0-2.1 60's w/ NO wheelspin.
Changed to 3.73's, had pcm4less do powerprogramming, and added slp loudmouth and went 13.5 @ 103.5 with crappy 2.0-2.1 60's still.
I just found out my car had 22#'s in it with programming for 24's, but I'd think the computer would have corrected itself over the 7k miles I've owned it. Now I have 30's with 30# programming so I'm all set :-).
Old Jun 24, 2003 | 11:25 AM
KGRESOCK's Avatar
With a CAI and flowmaster muffler my 95 was
pulling 13.60 all day with a 13.48 best.
Kevin
Old Jun 24, 2003 | 04:44 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
my wife's car with cai, and catback and 3.73 went 13.49 @ 101.2mph. only removed spare, and upper portion of back seat
Old Jun 24, 2003 | 05:29 PM
mavricki18's Avatar
can a stock car come with a 3.73 from the factory?
What gear dose a 99 M6 SS have in it?
Old Jun 24, 2003 | 06:24 PM
Timberwolf's Avatar
A. no
B. 3.42
Old Jun 24, 2003 | 08:18 PM
MBonZ28's Avatar
I went 13.6 with a SLP CAI, march pulley and flowmaster muffler
this was a M6 convertible on a 2.0 60ft
I ditched the stock cat back, yanked all the seats and carpet and managed a 13.32@104 with a 2.0 60ft. this was with stock manifolds,cats 3.42 gears etc
Old Jun 24, 2003 | 11:53 PM
mavricki18's Avatar
all your LT1s are faster than my LS1!
Or maby i just cant drive it
Old Jun 24, 2003 | 11:56 PM
Timberwolf's Avatar
no worries man, MY ls1 car only runs 13.95!!
and I can drive just fine.. it's the convertible top weight, 2.73 gears, etc
Old Jun 25, 2003 | 12:07 AM
mavricki18's Avatar
makes me feal a little bit better but wont be satisfied untill i see 13.5.
So you have an LS1 camaro to scoot around in and the 94 is a project car kinda thing?
Old Jun 25, 2003 | 06:35 AM
Timberwolf's Avatar
yeah, the 99 drop top is mainly driven by the wife these days
Old Jun 25, 2003 | 07:28 AM
smasher94z's Avatar
My 94 z28 went 13.88@99mph with only throttle body bypass and no converter and a flowmaster at Milan on balding GSCs
i had to feather the $hit out of it to keep from blowing the tires off
I got stock gear and stock intake
Lederman1976
Nov 30, 2014 05:21 AM
USAirman93
Nov 24, 2014 03:37 PM
Zomie
Jul 25, 2002 07:52 AM
Zomie
Jul 22, 2002 07:43 AM
Zomie
Jul 22, 2002 03:34 AM
