NY incpection
NY incpection
i have a 98 z28 everythign will pass but it has the check engine light on because of the egr was removed from the previous owner. if i go with my ls1 edit and make so the light dose not come on will this trick the NY inspection machine or will the ny comp no there really a DTC. any lope holes in the ny system?
Re: NY incpection
My friend removed the EGR on his GTP, and had the code removed. But on the NYS Inspection computer it showed up. something about how the test was incomplete....
You may have better luck, but don't be surprised if you fail. I dunno if you can find an EGR spoof, but thats what he ended up having to get, and that simulated the EGR test enough to fool the NYS Computer.
Re: NY incpection
the deal is ur car has to not have a SES light on(or anyother light) and u have to pass 3of 5 ready states , ur egr is one ready state which means u can fail at least one more , and still pass (99-02 or 00-02 has to pass 4of 5 readys states i cant remember which ) , i beleive u are reccomeded to fix teh problem still
ready states include, egr, air , rear o2s not sure of teh others
dont quote me on this but get it deleted out and u may be able to pass
