Middle Atlantic New Jersey, New York, and Pennsylvania
Need LT1 Heads
Old Sep 6, 2011 | 05:53 PM
zmanlt1's Avatar
Need LT1 Heads
As the title says, I need heads for a 95 LT1 Trans Am. Let me know what you guys have.
Old Sep 30, 2011 | 01:06 PM
Lt1son's Avatar
Re: Need LT1 Heads
Well i have a set of iron heads... doubt thats what you want but figured id put it out there
Old Oct 22, 2011 | 12:26 AM
dennis5374's Avatar
Re: Need LT1 Heads
I have a set of aluminum lt1 heads. Comp beehive springs, manly stainless valves, 51cc chambers. They've been milled 020 thousandths too bump compression. The only issue with these heads is cylinder 1 hole is stripped and had too be fixed with a metal sleeve. It holds excellent too low 11 second passes with a 150 shot. I just paid 600.00 dollars too have them cleaned up and fixed from the previous builders f*** up. If you want them they'll be available next week. I wanna get 500 out of them non negotiable. The valves and springs cost way more than that. Heads also have brand new guides as well. Email me @dennismurray98@gmail.com. these are the heads that got me too the 10.8@ the track
Old May 14, 2012 | 07:20 PM
ledfootz28's Avatar
Re: Need LT1 Heads
I have stock heads off my 94Z.Im pretty sure their aluminum stock.
Had about 110k when taken off but had no probs at all.Ended up rebuidlin the entire motor and getting afr 210cc lt4 heads.
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
