Middle Atlantic New Jersey, New York, and Pennsylvania
need help near albany w/ valve lash
Old Sep 23, 2007 | 06:30 PM
plaf713's Avatar
having trouble adjusting my valve lash on my 1994 z28. i could really use some help. if anyone has the time i would really appreciate it. just pm me and i will get back to you
thanks
paul lafreniere
Old Sep 25, 2007 | 07:54 AM
Pampered-Z's Avatar
Not near you but what type of problem are you having. maybe somethng we can do over the net?
Old Sep 25, 2007 | 11:49 AM
plaf713's Avatar
i am having a difficult time figuring out why i cant get my valves adjusted correctly, i did the # 1 and # 6 cylinder technique with spinning the pushrod until it couldnt move, then set a 1/4 preload. so i thought i was alright and put the intake manifold back on and when i started the car, some ofthe rockers became loose, Something about adjusting valves that i just cant figure out, mayb its just me. My mechanic warned me about adjusting the valves.
Old Sep 25, 2007 | 12:39 PM
Pampered-Z's Avatar
Do one rocker at a time. Turn the engine over until the lifter starts to come up ( say intake valve ), then adjust the exhaust. Spin the pushrod and turn down the nut until you start to feel the tension, and the pushrod doesn't spin as freely 9 Zero-Lash ), then tighten 1/4 turn. Turn the engine over until the exhaust starts to open and adjust the intake valve the same way.
If you running after lifter such as Comp R's then only go 1/8 past zero lash.
John B.
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
