Middle Atlantic New Jersey, New York, and Pennsylvania
NE Ohio (Akron, Canton, Youngstown ETC.)
Old Mar 10, 2005 | 10:17 PM
  #16
rickyzZ28's Avatar
Re: NE Ohio (Akron, Canton, Youngstown ETC.)
Let me know I am in for some track days. rickyzZ28@hotmail.com
Also Grease did you happen to see the 604 whp Civic that a buddy of mine and I built up there about 2 months ago?
Old Mar 10, 2005 | 10:58 PM
  #17
gmr speed's Avatar
Hey lou ( speed2much ) hows the car going? Hope you like it. Let me know when you need more stuff done. Hopefully the weather brakes and we can get that dynoed. My car is almost done.
Old Mar 11, 2005 | 09:32 AM
  #18
DarkHorse's Avatar
I heard about that Civic - pretty wicked.
Old Mar 11, 2005 | 09:53 AM
  #19
CANTONRACER's Avatar
I was there when it dynoed...interesting..but what a hoopty that stout little motor was stuffed in.
I personally think they could have hit 700 @ the wheels if they had all the bugs worked out.
Old Mar 13, 2005 | 12:28 PM
  #20
Grease's Avatar
No, I wasn't there that day, I saw the dyno charts the next day. AFAIK that the most powerful import car we've had there.
Old Mar 14, 2005 | 04:41 PM
  #21
MunsonGTA's Avatar
i was there right after it dyno'd and they had left, heard it was a pretty badass ride except for the body
Old Mar 15, 2005 | 08:08 PM
  #22
lsracing's Avatar
Tuning at bigshot will be in full swing as the weather breaks. From full blown tunes to normal dyno runs, Big Shot Dyno is the place to go. Thanks to all who support our LSRacing chips custom tunes. For all your cars needs, visit Big Shot Dyno and they can take care of you. Lets hope for good weather soon as the dragstips will be opening before to long.
Jamy
Old Mar 16, 2005 | 10:16 PM
  #23
jer4251's Avatar
This is for the guys who work at Big Shot Dyno. I have a few different mods done to my 97 SS and have a OBD1 conversion from madz28.com. is there much more to tuning my car than what i already have? It still feels like i have some kinks to work out somewhere. and i still feel i should be making more power to the rear wheels. I live right outside of youngstown and would like more info on having my car dyno tuned up at your place. the deal wouldnt hurt either ,
I have a quick question, after i had my car tuned with the OBD1( at the time i had ported MAF ends) and it was tuned for them. since then i bought a granatelli MAF and i kept getting an engine code every so ofter after the car would stumble while driving. I called the co. and they said it was probibly caused by the computer change i did. so now i have it tuned for the ported ends, but im driving with a completely stock MAF. have you ever delt with anything like that? should i contact the guy at madz28 and ask him about it? I'm sitting here with a $320 part i cant use.
thanks
jerry
Old Mar 17, 2005 | 12:38 PM
  #24
DarkHorse's Avatar
thanks
jerry
You can use Tunercat to tune the car - you would need the program and an aldl connector to do this.
I helped tune Grease's car on the dyno and we picked up about 20 rwhp over the base PCMForLess tune. I'm going back up there hopefully tomorrow to fine tune my car - i'm no expert but i'm a learner and have to do things hands on. There's guys out there that can do a MUCH better job at tuning for things like part throttle driving and such but since I work on computers for a living there's no way in hell I would let someone else tune my car. I'd much rather make mistakes and learn to do it myself.
If your not interested in learning then I'd recommend you contact Keith @ Big Shot and he can get Jamy from LSRacingchips involved, he'll tune the crap out of it.
Good luck!
Old Mar 19, 2005 | 12:17 PM
  #25
Grease's Avatar
thanks
jerry
You should contact madz28 and tell him to make a change to your pcm for the granatelli maf sensor. The Granatelli maf sensor was designed to be a true bolt on with no pcm changes required. Its designed for the stock maf tables. So when you have a pcm tuned for a ported maf then you run a granatelli maf it could throw you drivability way off.
If you have a cable to hook your car up to a laptop, there is a freeware program called MAF20. Basically it adds 20% to you MAF tables values if you have a ported MAF. It will also do the opposite and take away 20% from you maf tables if you go back to a stock sensor. You don't need Tunercats or LT1edit to make the changes. Just a way of getting your bin or lt1 file.
Old Mar 20, 2005 | 09:57 AM
  #26
MunsonGTA's Avatar
If you're interested in one of our lsracingchips tunes then check out our website. www.lsracingchips.com
i'll show jamy your post and see what he says about your setup.
IndyZman
Oct 22, 2015 02:17 PM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
heus
Sep 8, 2015 12:01 PM
