Any good body shops in nj?
The best body shop anywhere is Foreign Specialties in Manville. It's far away, but worth it. Ask for Larry.
The Original BIG Show
Director: MAFBA - NJ
CJC/FO Member: <A HREF="http://cjcfo.fbody.com/index.htm
2001" TARGET=_blank>http://cjcfo.fbody.com/index.htm
2001</A> Z28
1997 WS6
1991 Z34
I saw in another post you work in Bristol. Check out John's Autobody (not me), on rt 13, not too far from Bristol. It's in Levittown across from the McDonalds.
Talk to John Reese
John
1993 Black Z28 M6
SLP flywheel/McLeod clutch, B+M ripper
IRS stage II heads, port matched intake, 58mm TB, Moroso CAI
Lingenfelter (Accel) 211/219 cam, 1.6 pro-magnum rollers
24 Lbs injectos, SLP AFPR, Accel 300+ ignition
Ed Wright custom programming
MAC headers/PBM coated, Mufflex 4" cat back W/Spintech
SLP - SFC, IRS - LCA, STB, APHR,
LPE 3.5" drive shaft, Spohn torque arm
3:42 gears, Mac - Rear support
17" SS wheel W/ 275 Nitto DR's
Pampered-Z home page
Talk to John Reese
John
1993 Black Z28 M6
John's auto body did my car when i put my ground effects and hood on and i wasn't too happy with the job they did; they also did my 89 camaro when i repainted it and that was ok but thanks for the help
There a guy in Hamilton or Yardville named Gary Betsy and he did a great job painting a friends 69 Hugger Orange Z28. I have his website at home and I'll post it later.
Jeff.
Jeff H - 69 Z28 Hugger Orange, GM crossram, GM fiberglass cowl induction hood, factory TI setup & factory installed JL8 4 wheel disc brakes - original #'s matching and documented, being restored), 87 Toyota 4Runner SR5 Turbo
Jeff.
