ZZ-9 cam in stock headed LT1
Old Mar 11, 2004 | 10:19 AM
Prorac1's Avatar
Any one ever do this swap, and what kind of numbers did you come up with. The way the cam favors the exhaust side, it looks like it would work really well with stock heads. Specs are as follows: 212 226 dur @.050, and .483/.520 lift with 1.5 rockers, .515/.554 with 1.6. Lobe seperation is 112. Thanks, Prorac1
Old Mar 11, 2004 | 11:46 AM
Prorac1's Avatar
And also, im getting the cam for free out of a friends TPI motor, other wise i would be going with a differant grind. But cheap is good. Thanks Prorac1
Old Mar 11, 2004 | 11:49 AM
WS Sick's Avatar
The ZZ9 is just slightly more aggresive than the Hott cam, so your performance will be on par with it. As a note also use the 1.6 rockers with it.
oldschool
Feb 9, 2016 09:21 PM
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
MJ_Z28
Aug 8, 2002 09:07 PM
Brian-94TA
Jul 31, 2002 02:52 PM
