zo6 maf
Old Jul 21, 2010 | 03:59 PM
camarolover97's Avatar
zo6 maf
Would you see a difference in performance with the zo6 mass air flow on the LT1?
Thanks George
Old Jul 21, 2010 | 04:12 PM
RamAir95TA's Avatar
Not unless your setup warranted a larger MAF. Even then, that's debatable.
Old Jul 21, 2010 | 05:32 PM
NJ-LE's Avatar
camarolover97:
Your LT1 MAF can deal with air flow mass that could translate into over 450hp. You'll need major mods to use it all. If you did use a Z06 MAF you would also need to reprogram the MAF sensor calibration tables to the Z06 values.
Old Jul 21, 2010 | 10:51 PM
thanks for the help, i appreciate it
George
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
