Zero lash? Help please.
Old Feb 25, 2006 | 01:02 PM
nb 96 z's Avatar
I took off my drivers side valve cover because there has been some ticking coming from inside the valve cover. It's consistent when I rev it up to about 1600 rpm and anything above that it disapears. A few of the push rods I can twist by hand and a few I can't. All of them need to not be able to twist or move right? These are stock pushrods and rocker arms. Thanks.
Old Feb 25, 2006 | 01:44 PM
nb 96 z's Avatar
Re: Zero lash? Help please.
anybody?
Old Feb 25, 2006 | 01:50 PM
FastZinTennessee's Avatar
Did you actually turn the motor over, stopping at testing each rocker arm when the corresponding lifter was at the base circle on the cam?? I would assume you did, as this would be the correct way, but you never know!
I would say that if you are running a stock valvetrain, there should be enough preload on the rockers that it is at least difficult to turn each pushrod by hand.
Old Feb 25, 2006 | 02:08 PM
nb 96 z's Avatar
Thanks. I'll go do that and check each pushrod again.
Old Feb 25, 2006 | 11:01 PM
You can't really check valve lash that way. Some will appear more loose than others depending on where the lifter is on the cam lobe.
Old Feb 26, 2006 | 11:58 AM
nb 96 z's Avatar
I see. Thanks.
9t4lt4z28
Oct 2, 2015 10:28 AM
navtool.com
Sep 24, 2015 03:30 PM
navtool.com
Sep 24, 2015 03:26 PM
navtool.com
Middle Atlantic
Sep 24, 2015 03:17 PM
Daluchman1974
Sep 11, 2015 06:12 AM
