z28 & vette engine/trans swap
Old Oct 7, 2011 | 12:22 AM
Rij1's Avatar
can I swap my engine and trans with a 94 corvette lt1 engine and 6 speed trans? What are the major conversion issues and would it be worth doing it
Old Oct 7, 2011 | 12:29 AM
ACE1252's Avatar
Re: z28 & vette engine/trans swap
The LT1 should go in fine, but the ZF 6 speed may have issues. IIRC, the vettes didn't get a T56 until 97.
Old Oct 7, 2011 | 12:34 AM
Rij1's Avatar
I can put my trans on the engine then? are all the parts inter changable on both engines?
Old Oct 7, 2011 | 12:50 AM
ACE1252's Avatar
Yes, I believe so....you may have to swap the oil pan as well.
Old Oct 7, 2011 | 05:18 AM
Are you in need of a replacement engine? There is no difference performance-wise between the Corvette LT1 and the F-Body LT1. The only internal difference is 4-bolt mains for the Corvette. Same heads, cam, etc. You will have to swap over your front accessory setup, the fuel rails (Corvette hard lines terminate in a different loaction), possibly the oil pan.
Your T56 will bolt up. The ZF trans could be made to work, but the T56 is basically a US-made (at least in 1994) replacement for the quirky German ZF. The T56 used in the 97 Corvette is a rear-mount setup, bolted directly to the differential housing, with a huge "torque tube" rigidly connecting the trans to the LS1 engine.
Old Oct 7, 2011 | 12:52 PM
Rij1's Avatar
I dont need to replace my engine I just found an engine/ trans with only 66,000 miles on it for $975 and mine has 152,000 so I figured it would be worth changing it or atleast using parts like the opti or whatever componants I would need to get mine running right then selling the rest.
rocketman051894
Jan 30, 2015 03:23 PM
bonniew
Events and Cruise Spots
Jan 18, 2015 01:14 PM
chuyz28
Jan 15, 2015 04:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
cryptopsy
Aug 19, 2002 12:19 PM
