Your thoughts on this SR cam?
Old Mar 13, 2012 | 01:27 PM
ChrisLS1Bird's Avatar
686/688
255/262
LSA 110*
108* centerline
This is in a 383 with AI 200cc heads. M6 transmission.
Where do you think the powerband ends with this cam? Does anyone else here have a cam this big in an occassional street vehicle (weekend car)?
Car's not fully tuned now, but driveability is surprisingly good (aside from the stench).
Old Mar 13, 2012 | 06:57 PM
joelster's Avatar
Re: Your thoughts on this SR cam?
What intake? With good flowing single plane it would rock. I'd say peak around 68-7000 with a single plane, and a few hundred less with a stock intake. You'd want an aftermarket pcm or an LSx conversion.
Old Mar 14, 2012 | 08:39 AM
slomarao's Avatar
The intake will be big for this cam. those heads are good, but some 220 AFR's would be much better.
what compression ratio?
Old Mar 14, 2012 | 10:23 AM
I'm using a ported stock intake (ported by Lloyd Elliot).
CR is ~ 11.28:1 (pump gas).
Maybe choking it down a bit with the top end I have.
Right now, it runs on an Ed Wright programmed PCM, but the programming is for a less aggressive setup. I am going to have Moe Bailey tune this on the dyno in the coming months. Then I'll know what I've got. Moe thinks he can get a handle on this using the stock PCM.
Old Mar 15, 2012 | 06:09 AM
joelster's Avatar
Moe is a very good tuner. I still owe him some beers. Tell him joelster says hi!
Klypto
Mar 23, 2016 09:05 AM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 13, 2015 11:48 AM
armedtrigger
Feb 24, 2015 08:30 PM
