compression to high???
Old Oct 17, 2006 | 08:55 PM
1redTA's Avatar
I bought an engine from a friend of mine, the compresion is around 12.5 to 1 The problem is the 9.4 dynamic ratio with the cam I am using 245,253@.640 on 112cl. the heads are milled to around 52 and the pistons are 5cc relief that were relieved for piston to valve clearance. I don't know wether to get some Trick Flow heads with the 62 cc or get some dish pistons....the heads on it went 10.4 with a little bigger cam, no nitrous 3400 lb car would it be better to get the pistons to lower my compression??? any ideas guys
Old Oct 17, 2006 | 09:20 PM
Ray@NitroDaves's Avatar
Re: compression to high???
Why are you wanting to lower compression? Is it for tuning, driveability, etc?
I am running 12.2:1 SCR and ~9.6DCR in my 94, 48cc combustion chambers, 246/254 .613/.590 112. Still run pump gas every day.
Old Oct 17, 2006 | 10:30 PM
Spinner's Avatar
You can easily run 12-13:1 static with the right combination of parts and tuning on pump gas.
Old Oct 17, 2006 | 11:28 PM
chy20k1's Avatar
you can run alot of compression... but 9.4 and 9.6 is really high for pump gas. i dunno about that
Old Oct 18, 2006 | 06:48 AM
1redTA's Avatar
yes I would like to run pump gas and I was told 9 is the limit on dynamic I haven't tried to run it on pump yet but I do not want to run race gas either or have to mix the two as a band aid
Old Oct 18, 2006 | 09:28 AM
Z-RATED94's Avatar
New pistons, no gain in HP. (and not cheap) A nice set of done up Trick Flows, more HP. Just my thoughts, if your sure you need to lower your dynamic.
Old Oct 18, 2006 | 10:08 AM
1redTA's Avatar
these heads are stock casting with the pushrods moved on the intake I have T&D shaft rockers with the intake offset and are set up for my solid roller cam. The tuning done before was on a FAST and the guy said the engine did not like a lot of timing, sign of effecient heads?, so maybe it will run on 93? I have never tried it but don't want to take it all back apart because it detonates after I put it in the car. Thanks ART
Old Oct 18, 2006 | 10:22 AM
WS Sick's Avatar
Those heads must have had some serious pushrod pinch work done to have the need of moving the pushrod.
You could look at a different cam that gave more pumping loss. What head gasket is used? If its a very thin one you could goto a stocker and lose close to a half a point there.
But to tune that high of a compression to work around town in all street driving conditions would take ALOT of trial and error tuning.
MikeWhitener
Aug 2, 2015 06:17 PM
fundone2000-RZ
Pacific
Jul 21, 2015 07:21 AM
SpeedJunkee
Jul 19, 2015 09:06 PM
13qtr
Jul 19, 2015 05:30 PM
mrwz28
Jul 8, 2015 09:11 PM
