You can't have any cooling if you can't heat your meat
Old Aug 14, 2003 | 06:06 PM
  #16
NOMAD's Avatar
Originally posted by Dan Oldham
Ok, I tried looking for the vacuum check valve, and notated the link to the picture, with the "elbow" and what-not, and there is NOTHING under the hood that even closely resembles anything that looks like that.
If it's there, I'm definitely NOT seeing it.
Mine was crammed back in there good, I actually had to pull it out into view.
-Shannon
Old Aug 14, 2003 | 07:35 PM
  #17
JSK333's Avatar
Mine was back by the PCM, kind of stuffed under convoluted tubing.
Old Aug 14, 2003 | 08:00 PM
  #18
bigdreamZ's Avatar
Dan thank you for posting this! I have been having the EXACT same problem recently. I will let you know what I did IF I manage to fix it...
Old Aug 14, 2003 | 09:44 PM
  #19
bigdreamZ's Avatar
Well I got home and checked and the hose that connects to the top of the vaccum check valve was cracked clean off. So I yanked up some slack and pugged it in an voila my AC works like new again. Thanks guys...Dan I hope your problem is as simple as mine was
Old Aug 14, 2003 | 10:04 PM
  #20
Dan Oldham's Avatar
Glad I could sort of help ya out, BigDreamZ. Thanks for the good wishes. Hopefully my problem is as easy as that also. I can only hope.
Well, back to the drawing board again tomorrow.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
