Yessss Another missfire
Old Aug 17, 2009 | 06:48 PM
  #16
Godly96_SS_Here's Avatar
Originally Posted by johnnyb
If I unplug the maf on my car it wont start or run; it dies right away.
If my memory serves me correct, there should be a pink wire going to the maf pigtail that should be getting 12v. you may want to check that (search to make sure thats the correct wire first though ) search "p0100" and you should be able to come up with it. Hope that helps
If I unplug my maf, nothing changes to the cars runabilty? Checked the pigtail and it is getting 12v also.
Old Aug 18, 2009 | 08:38 PM
  #17
Errrrr
OK, Im getting out of options here with my car. I really don't have this much experience with dealing with a phantom misfire that I have no idea where to start looking. The MAF doesnt seem to be the issue since i replaced it and there is no change, i have replaced the plugs and inspected the wires thoroughly. Does anyone know where in the Portland are i might be able to take it to get looked at? someone who knows the LT1's?
Old Aug 18, 2009 | 08:45 PM
  #18
AZ2ENVY's Avatar
what are the spark plugs gapped at ?
Old Aug 18, 2009 | 08:52 PM
  #19
I don't know? Whatever they came out of the box at? They are the NGK TR55's I was told they are an upgrade for my car. Should they be different then what comes from the box?
Old Aug 18, 2009 | 09:23 PM
  #20
rclearyiii's Avatar
Fuel Injectors?
You mentioned that the plugs on one side smelled like gas. Have you checked for any injectors that may be leaking?
Old Aug 18, 2009 | 10:21 PM
  #21
Do I just pop em out and turn the key to the on position? or is there a procedure?
Old Aug 18, 2009 | 10:39 PM
  #22
rclearyiii's Avatar
Test
That is one way to do it by removing the fuel rails with the injectors still attached and turn the key on and see if there is leakage. You could also put a fuel pressure gage on and turn the key on and see if the pressure leaks down quickly.
Old Aug 18, 2009 | 11:29 PM
  #23
I will try by removing the injectors out tomorrow, the car misfires so bad it can't be driven, Idles ok but anything over 1500 rpm just goes horrible.
99 z28 Haas
Apr 23, 2004 07:25 PM
street demon2k3
Mar 27, 2004 08:27 AM
eds96ragtop
Mar 5, 2004 04:43 PM
MattysTA
Feb 7, 2004 12:20 PM
ledfootz28
Nov 8, 2003 07:28 PM
