Yes or No?
Old Apr 15, 2006 | 08:33 PM
cg4743's Avatar
Yes or No?
I'm about to install the LT headers and do away with the o2's. I've already got a new pcm programmed for this as well as the egr and air deleted. My question is should I remove all of the EGR and AIR parts or just leave them there/
Old Apr 15, 2006 | 08:48 PM
robyrd's Avatar
Re: Yes or No?
Yes
Old Apr 15, 2006 | 08:50 PM
cg4743's Avatar
Re: Yes or No?
Yes take them out?
Old Apr 15, 2006 | 09:15 PM
respectirocz's Avatar
Re: Yes or No?
yes take them out, save weight, clean up the compratment
Old Apr 15, 2006 | 11:28 PM
96trans am's Avatar
Re: Yes or No?
Yeah take them out. If you didn't what was the point of programming them out? The deleted AIR and EGR doesn't really have any performance gains. More of a space issue and maybe a tiny bit of weight.
Old Apr 16, 2006 | 02:37 PM
2000GTP's Avatar
Re: Yes or No?
You never mentioned if emissions are an issue in your area. If so, then removing the AIR and EGR may be a problem. Also, did you already buy the long tubes. If you already did, and if they do not have provisions for AIR and EGR systems, then you are forced to remove those systems anyhow.
