Which year LT1 had PINK RODS
Old Feb 23, 2004 | 09:54 PM
xxsaint69x's Avatar
from what i have read on here 92-94 LT1s had the PINK Rods, and 95+ had the PM rods. IS THIS TRUE?
Marcin
Old Feb 23, 2004 | 09:57 PM
LimitedEd1LE's Avatar
I thought 93-95 had the pink rods? But I could be mistaken.
Old Feb 23, 2004 | 10:15 PM
88RX7LT1's Avatar
No pink rods on my 95 . . . big boy :0
jfk on the "big boy :0" The rest is correct.
Old Feb 24, 2004 | 02:11 AM
BBoyce's Avatar
The pink rods where replaced by the powdered metal rods in mid 94.
Ben
Old Feb 24, 2004 | 09:07 AM
Sleeper_Z's Avatar
My B4C was built in november of 93 so im guessing its got Pinks. So which is better Pinks with if im not mistaken are just shot peened stock forged rods, or Powderd Metal rods? Im getting ready to go threw my 95 LT1 and im just wandering if i would be better off yanking the 94 LT1 out of my B4C. Thanks alot.
Jeremy
Old Feb 24, 2004 | 09:38 AM
Camaro_Guru16NY's Avatar
why were they pink to begin with, out of curiosity?
Later,
-John
Old Feb 24, 2004 | 09:42 AM
Sleeper_Z's Avatar
Camaro_Guru16NY why were they pink to begin with, out of curiosity?
The reason the are called "PINK" rods are because from the factory the were shot peened and stress relived and then had a pink paint dot put on them to tell them from other rods. Thats why there were called "PINK" rods. Hope that helped.
Jeremy
Old Feb 24, 2004 | 10:29 AM
From the "Rebuilding the LT1" article....
RODS
350 - The original LT1 came with regular forged 350 rods, that were shot peened for localized hardness under the head of the bolt and nut. Powdered metal rods were phased in for the Corvette around 1994 and used in all of the LT1 engines by 1995. GM made the change because the powdered metal rods were cheaper to make and were much stronger than the GM high performance "pink" rods. In fact, they are supposed to be good for up to 450 hp. They are machined at the parting line so they can be reconditioned.
The two cases I have seen of PM rod failure were both at about the 600HP level.
Old Feb 24, 2004 | 10:37 AM
Sleeper_Z's Avatar
Hmm well thats good to know. I guess I'd be better off going into my 95LT1 then. Thanks for the info.
Jeremy
Old Feb 24, 2004 | 10:58 AM
WS Sick's Avatar
The newer rods are much better than the 92-93 rods. take a look at the early LT1 rods, they were pink only in name, I have a set of pink rods , which are basicly a regular set that are magged and bead blasted, and they are much meatier than my 93s stock rods were, heck the rods out of my 79 350 block were beefier than the 93s , the shafts were NOTICEABLY thinner ,I mean like a good 1/8 th an inch!!!!
Old Feb 24, 2004 | 02:36 PM
RallyRed701/2's Avatar
if the "pink" rods were so much weaker than why did they use them in the first place, and why were they considered performance rods?
Old Feb 24, 2004 | 02:44 PM
Red96Lt1's Avatar
Metallurgy my friend.
Old Feb 24, 2004 | 02:57 PM
neil350's Avatar
The 91-92 Firehawks also had pink rods. For stock use their fine, thats why GM used them.
Old Feb 24, 2004 | 04:35 PM
scoobysnax83's Avatar
167,000 miles total, 10,000 miles on fully ported and polished heads and a cam and my pink rods are still happy. So there.....
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
Jul 4, 2005 05:00 PM
