Yank SS4000
Old Jul 3, 2020 | 05:56 PM
Corona95's Avatar
Yank SS4000
is there any place sells Yank torque converter beside Texas speed and performance?? and is $950 the right price?
Thank you..
Old Jul 4, 2020 | 03:48 PM
Chimera96's Avatar
Re: Yank SS4000
YANK site says $950....YMMV
Old Jul 4, 2020 | 04:52 PM
Re: Yank SS4000
PCM of North Carolina gets $950 for a Yank SS Series.
https://www.pcmofnc.com/product/yank-4l60e-converter-3/
Old Jul 5, 2020 | 09:21 PM
Corona95's Avatar
Re: Yank SS4000
Thank you..
just ordered AAM 4.10 gears and now it's time to torque it..
first stall car in my life.. going big..
Old Jul 6, 2020 | 08:07 AM
adam85's Avatar
Re: Yank SS4000
That’s what I paid for mine many years ago. Very nice converter!
Old Jul 6, 2020 | 09:52 AM
Chimera96's Avatar
Re: Yank SS4000
Originally Posted by Corona95
Thank you..
IMHO you REALLY want to run a additional trans cooler with a stall that high..would be a good idea to run a trans temp gauge
Old Jul 6, 2020 | 10:50 AM
Re: Yank SS4000
And you're running a 4,000 RPM stall and 4.10 gears behind a "(100% Bone Stock)" engine?
Old Jul 6, 2020 | 04:09 PM
Corona95's Avatar
Re: Yank SS4000
can't post them.. have to install them first..
just got my 4.10 gears and had to return them.. they belong to 3 series and i have 2 series.. do AAM make a 4.10 gear for a 2 series carrier??
Old Jul 6, 2020 | 04:12 PM
Corona95's Avatar
Re: Yank SS4000
Already on the list.. any recommendation on the brand for the cooler..
thank you..
Old Jul 6, 2020 | 04:14 PM
Corona95's Avatar
Re: Yank SS4000
how much did it cost you to put in??
Old Jul 6, 2020 | 05:24 PM
adam85's Avatar
Re: Yank SS4000
I installed it myself if that’s what your asking. Just fluid and a retune.
Old Jul 6, 2020 | 09:54 PM
Corona95's Avatar
Re: Yank SS4000
"installed it my self"
What's wrong with me if i only had my own parking garage.. Lucky you man.. honestly if you had said 1,000.. it would have felt much better..
Respect
Old Jul 7, 2020 | 08:36 AM
FirstYrLS1Z's Avatar
Re: Yank SS4000
What's wrong with that ? Or why not !
Old Jul 7, 2020 | 09:27 AM
Chimera96's Avatar
Re: Yank SS4000
I don't think you can run 4:10 or anything lower than 2.xx gears in a series 2 carrier
thank you..
depends on where you mount the external trans cooler. Size & shape will be dictated by that. Brand is not important, coolers are a simple device
so a 4k stall and 4:10's on a 100% stock motor....wtf. Lower gears I can see but a 4k stall on a stock motor...might want to consider something closer to 2800 or lower. TC stall and cam specs are what you want to match
If you are not doing this work yourself it can cost some $. Rear gear swap is generally $250-$500 labor if you supply parts. Trans shop likely charge at least $500 to R&R trans to put in a TC. Plumbing in a cooler, IDK but assume shop hr labor rate times x hrs
Old Jul 7, 2020 | 10:56 AM
Re: Yank SS4000
Most A4 owners opt for 3.73 gears, to keep at least part of the benefit of the O/D 4th gear ratio (0.70). With 26" tires, 3.73's will cruise at 70 MPH at 2,360 RPM. With 4.10's RPM jumps to 2,600 RPM. I run 4.11's with an 0.78:1 O/D. Cruises close 3,000 RPM at 70 MPH with street tires - not a lot of fun. But it's a "track" car, not a daily driver.
The idea of the stall is to put the engine into it's peak RPM range for a potent launch. But a totally stock LT1 in an F-Body is past it's peak torque at 4,000 RPM, and the torque is starting to nose dive rapidly. The LT1 has such a flat torque curve from 2,500 - 4,000 RPM that you would be much better off with a 3,000 RPM (or even lower) stall to maximize the "area under the curve".
As far as running 4.10's in the 10-bolt with a 2-series carrier, you can buy gears sets specifically for that application from several manufacturers. Here's one example
https://www.strangeengineering.net/p...2-series.html/
