Yank 2600 for LS1, will it work for LT1.
Old Jul 16, 2005 | 04:33 PM
atlasengr's Avatar
Guys,
I have a chance to get a Yank 2800 Torque Converter from a buddy of mine but he had it installed on his '02 Z28. I would like to get it if it fits my 1995 Z28.
Will this work out for me or what are the differences that are going to keep me from doing this?
Thanks!
Old Jul 16, 2005 | 04:41 PM
simple's Avatar
Re: Yank 2600 for LS1, will it work for LT1.
nope.
only things interchangeable from LS1 years too LT1 years is gonna mainly be suspension/chassis parts and some appearance stuff
Old Jul 16, 2005 | 06:37 PM
atlasengr's Avatar
If both automatic transmissions are 4L60E, then are the input shafts longer, shorter, more splines or what?
Old Jul 16, 2005 | 06:39 PM
Dave89IROC's Avatar
LS1 input shaft is longer for sure, the bolt pattern to the flexplate might be different as well, no real reason to check
Old Jul 16, 2005 | 06:59 PM
MyGreenBabyZ's Avatar
i went through this when i built my car up. i had a converter from a friend that had an ls1 and it wouldnt work for me. the splines are the same as are the input shaft length but because the bell housings on the ls1 cars is a bit longer the torque converter is taller.
so in summary you CAN'T use a LS1 torque converter in an LT1 Car.
Old Jul 16, 2005 | 09:25 PM
atlasengr's Avatar
Dammit! My Luck!
Old Jul 16, 2005 | 10:56 PM
JKDZ28's Avatar
It will NOT work sorry.
Old Jul 17, 2005 | 05:04 AM
94 TA TT2S's Avatar
I believe one will from a C5 corvette.....
Old Jul 26, 2005 | 05:01 PM
WS Sick's Avatar
Ok I have personnal experience with this, it will not work at all, the LS1 input shaft on the 4L60 E is completely different, it doesnt even seal to the converter the same.
I recently put a 00 4L60E behind an LT1 in a 91 S-10, the tranny will bolt to the LT1 and you can use the LS1 converter with it and its practicly a bolt together, but the converter from the LS1 must come along.
rideordie
Nov 5, 2019 04:52 PM
Brake_L8
Jan 20, 2015 09:44 AM
nballisru
Dec 14, 2014 05:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
