y pipes
y pipes
i saw some jet hot y pipes for 260, are these any good?? i'll be hookin them up to a slp loudmouth system.
i actually found a pacesetter y pipe system for 130, are these any good, or will they work good with the slp cat back system?
Re: y pipes
Go with the jet-hot Y-pipe, I did. It is actually a hooker y-pipe but jet-hot branded it. Pretty much, i got Jet hot long tubes (no egr/air), Jet hot 3" Y-pipe (it does not come with cats, it comes in 3 peices that slide fit and lock together) and the SLP loudmouth exhaust. This bolted up 100% without any cutting or welding, did it in my buddies garage. The Y-pipe even comes pre bent to clear the trans brace
so with the jet hot y-pipe, you wont be disapointed. Jet hot is prob also running a speical for the combo, they always do.
Re: y pipes
My setup sounds like the world is going to end hahaha, i like it personaly. Other people hate it, but if you think about it, it aint gonna get any more free flowing with an exhaust then my setup, Remeber the Loudmouth doesn't have a muffler, its just an overside pipe in the exhaust piping that they call a "resonator". Depends on what you want, i love mine, other people would say other things.
