what is wrong with my bone stock dyno???
http://www.corral.net/photopost/show...at=6246&page=1
could it be that i was running cheap 87 oct. gas..i have a miss too.. at wot, when shifting into second..well when the trans shifts..the car bucks and stops and the rpm stays the same..also when on the highway in overdrive at low rpms' i noticed the rpms were going up and down.."missin"
Re: what is wrong with my bone stock dyno???
you make more power than I do with the mods in my sig... I think the question is whats wrong with my car lol.
http://home.comcast.net/~zigroid/firebirddyno2.JPG
GrannyCar i think it might be something electrical because of the Bouncy band or maybe the car wasn't well straped to the dyno. But the power isn't that bad for a stock LT1 A4. I got a friend with a 94 z28 (100k miles) made 248 rwhp and i dont remember the tq but that was with a CAI.
Zigroid it looks as if you are running rich, but i notice that the tq on the 2nd pull was defenitly wrong 220 lbs-ft.
Originally Posted by stereomandan
Looks correct, except for how bad the curves are.
244 rwhp 285 rwtq is right on for a stock A4.
Dan
Dan
You shouldn't be running that low octane, it will cause the engine to run rich/lean back and forth, trust me I know.
How do you know the problem isn't such that when kicked up to 5 or 6 grand wouldn't blow the engine????????? Seen plenty of blown head gaskets causing misfires and that situation could easily hydro lock. OUCH.
Bill Engvall said it best
Here's your sign
first off speedy gonzales, i didnt know i had a problem nor would anything cuase a problem..second my head gaskets were just done about 2000 miles ago and the heads were machined down....
what electrical things could be going bad? spark plugs/wires, opti? coil? are they hard to install?
