Y-pipe question
Old Jan 17, 2006 | 08:48 PM
BlackMagic's Avatar
Y-pipe question
Put headers on over the weekend and took my 94 TA to the exhaust shop to get a Y-Pipe made and get it all connected he said that i'd have to relocate my fuel lines and brakeline under my door. Do I have to relocate, or just quit being a cheap *** and buy a y-pipe already made.If i do but one, will I still have to relocate?
Old Jan 17, 2006 | 08:54 PM
2000GTP's Avatar
Re: Y-pipe question
What kind of headers are you running, long tubes?? As for the y-pipe, what kind of y-pipe are you having made, one with or without cats? I can see the exhaust shop saying that they may have to reroute the brake/fuel lines as they are in that general area. But depending on what headers you have, there is a good chance that there is a pre-made y-pipe that you can buy and you will not have to worry about a custom y-pipe or rerouting your lines.
Old Jan 18, 2006 | 09:36 AM
BlackMagic's Avatar
Re: Y-pipe question
Will this work the best to go with the pacesetter long tubes?
will I still need to relocate my fuel lines?
Old Jan 18, 2006 | 03:56 PM
2000GTP's Avatar
Re: Y-pipe question
The link you gave directed me to your cart which had the Pacesetter long tubes in it. I am guessing you are wanting the y-pipe right? The y-pipe that will work for those headers is the Pacesetter ORY pipe and the Summit part number is: PSM-82-1161 and it runs 130 dollars. I used this y-pipe with my Pacesetter long tubes and it did not interfere with the brake or fuel lines. Plus, the y-pipe is only 130.00, I'm willing to bet you that is much cheaper then what the exhaust shop wants to make you a custom one.
Old Jan 18, 2006 | 05:03 PM
Jeff H's Avatar
Re: Y-pipe question
The y-pipe will run right next to the fuel and brake lines so you should either get some heat wrap to put around the fuel/brake lines or wrap that section of y-pipe to keep the heat away from the fuel lines. I did both, wrapped a section of the y-pipe and then put some heat wrap around the fuel lines.
Old Jan 18, 2006 | 09:40 PM
1995greenTA's Avatar
Re: Y-pipe question
I was going to have a shop fab up a y pipe and they said it would be alot cheaper just to buy one.
Old Jan 18, 2006 | 09:52 PM
MetallicTrans96's Avatar
Re: Y-pipe question
I just made my own....took stainless 3" pipe and made a Y...looks just like an SLP Y pipe for an LS1
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
Mike94ZLT1
Jul 31, 2002 01:50 AM
