Y-pipe hitting floorboard...suggestions?
Old Mar 31, 2004 | 07:46 PM
  #16
Hawk's Avatar
solid motor mounts, I had some header issues when the motor torqued but solid mounts fixed that.
Old Mar 31, 2004 | 08:17 PM
  #17
justahoe's Avatar
I just used a peice of heater hose. Work so far for me.
Old Apr 1, 2004 | 07:49 AM
  #18
93transam1234's Avatar
The heater hose didnt melt?
My y-pipe is touching my frame and when i drive inside the car it fells like a have 15" subs blasting lol
Do you think the heater house will stop the vibration too?
Old Apr 1, 2004 | 07:54 AM
  #19
ppmz28's Avatar
I don't know where mine is hitting, just under the pass. side. I believe the muffler shop told me that it is hitting some plate that moves and flexes when you go. But it only does it at WOT!
Old Apr 1, 2004 | 09:26 AM
  #20
ShelbyZ28's Avatar
What kind of mounts did you get and where did you buy them at? I have this problem as well and i'm pretty sure my mounts are shot. Thanks!
Bryan
Old Apr 1, 2004 | 09:52 AM
  #21
teke184's Avatar
just get some prothane motor mounts from thunder racing for $50
takes a little while to install but it completely eliminated the engine twist on my LS1.
and NO increase in vibrations were noticed
Old Apr 1, 2004 | 10:16 AM
  #22
Hawk's Avatar
Bryan
I believe I got them from summitracing.com.
Poly will be stiffer then stock, but nothing is as stiff as solid steel. And yes, you will get some vibes over stock, an expecially with a cam, you'll feel it. Which, is not really a bad thing,
Old Apr 1, 2004 | 07:27 PM
  #23
justahoe's Avatar
The heater hose hasn't melted yet been in for a couple of weeks, and the rubber kinda acts like a bushing.
Old Apr 1, 2004 | 07:38 PM
  #24
Mikey97Z's Avatar
I had the same problem with my FLP pipes. I tried bending them with a huge prybar, and I used to wrap it with header wrap. The poly motor mounts finally solved it and I am really happy with the mounts. The car feels great.
Old Apr 1, 2004 | 08:13 PM
  #25
Cmr0z28's Avatar
Thanks guys....I put a piece of hose in there, from my AIR system, and it seems to absorb it okay...much better than the grinding noise of metal on metal. I'll come up with something better one of these days, but for now this will do.
PopoFormula
Oct 12, 2015 04:19 PM
WobblySausage
Oct 7, 2015 10:09 AM
Hal Fisher
Sep 30, 2015 09:03 PM
SergheiS
Sep 29, 2015 08:56 PM
alliance12364
Sep 23, 2015 12:40 PM
