Y-Pipe fitment question
Old Feb 21, 2006 | 10:25 PM
robyrd's Avatar
Ok guys, I have searched, but to no avail! I was under the impression that if I got the pacesetter off-road y-pipe, to go w/ their lt headers, that the y-pipe would bolt right to the rest of my stock exhaust system. I have a friend, however, who told me I would also have to have an intermediate pipe to go between the y-pipe and the rest of my stock exhaust because they were different diameters.... any help clearing this up would be appreciated!!
Travis
Old Feb 21, 2006 | 10:50 PM
3gc's Avatar
3gc
Re: Y-Pipe fitment question
The y-pipe is 3" so if you have a stock cat back you will need a reducer. But you could probably pick one up for a few bucks at a muffler shop. The y-pipe exits around the middle of the driveshaft tunnel. You'll have to cut the stock itermediate pipe. I took the intermediate pipe out of my car and brought it to a shop to get expanded so it was a simple slip fit. My cat back has a flange on the muffler so it's easy to do, if it was welded I would have figured another way.
Old Feb 22, 2006 | 12:03 PM
1quickTA's Avatar
I took mine to an exhaust shop around the corner and they just expanded the pipe a bit for me. I brought the pipe that it had to fit to so that they could make a good fit. Didn't even charge me for it. I would recommend that route.
Old Feb 22, 2006 | 12:29 PM
HardcoreRM125's Avatar
I have a flow master catback. It was the same diameter. I had to cut the bent portion of the intermediate pipe (Like the last few inches before where the Cat is. Then I just sleeved it there. Got good clamps and cranked it down. No leaks and it took 20 minutes with a sawzall.
Jun 6, 2015 08:27 AM
CARiD
Jan 14, 2015 04:00 AM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Jan 4, 2015 11:15 AM
