xe224/230 or cc306
Old Jun 12, 2003 | 10:32 PM
  #16
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
I think the 306 CC is a better choice for a 6spd based on results I see here.
I would hesitate to say the same with an auto...
just based on what i've seen here. I dont have any expeirence with the 306 in my own car.
  #17
97WRAITH's Avatar
Marcin thanks. Do you remember where you got that crane spring kit from and how much you paid for it?
Rob.
Old Jun 12, 2003 | 10:34 PM
  #18
xxsaint69x's Avatar
yeah..i dont know how the CC306 would feel in a auto either.confused:...is there anyone on the board that has a CC306 in a auto car? How drivable is it, and what kind of stall are they running?
Old Jun 12, 2003 | 10:36 PM
  #19
xxsaint69x's Avatar
Rob.
http://www.summitracing.com
part number #CRN-10308-1
cost $146, comes with everything you will need.
Marcin
Old Jun 12, 2003 | 10:40 PM
  #20
97WRAITH's Avatar
Thanks Marcin CC306 it is.
BTW just made my buddy Taner happy; he wants me to get this cam.
Rob.
Old Jun 12, 2003 | 10:41 PM
  #21
treyZ28's Avatar
Marcin
I had that kit and liked it,
but I now I would (I just did actually) go with combination motorsport springs. They are actually cheaper i think- dont quote me on that because my springs are a BIT stiffer and my retainers have a BIT more titantium than that kit
Old Jun 12, 2003 | 10:44 PM
  #22
xxsaint69x's Avatar
Rob.
My car sounds like his too bad its not as fast Is he using the CC306?
Old Jun 12, 2003 | 10:49 PM
  #23
97WRAITH's Avatar
He is running a solid roller cam with crazy lift like 680" if I remeber correctly. I don't think he would run a 9.60 Et with a cc306. LOL
Rob.
Old Jun 12, 2003 | 10:54 PM
  #24
97WRAITH's Avatar
Marcin I forgot to ask you are using stock fuel pump and injectors?
Rob.
Old Jun 12, 2003 | 10:55 PM
  #25
xxsaint69x's Avatar
Rob.
yup.
you can see my car in action here
http://bellsouthpwp.net/L/T/LT1Ultra...rcin115mph.mpg
Old Jun 12, 2003 | 11:12 PM
  #26
Z95m6's Avatar
I personally wouldn't get the CC306. I have a 230/236 with ported heads in my car and i think it is on the edge of being unstreetable if you ask me. It has some cam surge and a loss of low end torque meaning you have to rev it to make the power. i believe looking at Kmook's dyno he didn't even really start making power with his 230/236 until like 4-4500. I am running stock gears and am putting in 4.10's this weekend or next and that may help the car some. I just wouldn't want any more cam than this and the CC306 is bigger plus it doesn't have the XE lobes which help streetablity.
Old Jun 12, 2003 | 11:22 PM
  #27
AENIMA95z28's Avatar
whats the main diff between the 30x series and the XE series cams. Allot of people here seem to think the 306 is a bit to big, how does the 305 and lower compare?
Old Jun 12, 2003 | 11:25 PM
  #28
O yeah myself being mainly a weekend driver, and having allot of 5-0 around here, what cam would you guys recomend. I dont have head work yet but i do see it in the distant future. Im thinkin 224/300 but i love the feel and sound of a large cam. You think this cam has what it takes to give that kinda thrill or is it too small ?
Old Jun 12, 2003 | 11:26 PM
  #29
treyZ28's Avatar
how about 224/230 on a 110 lobe seperation with the "middle lift" (there are 3 lifts available)
check out my thread in advanced tech called "using LSA to adjust powerband"
around the 3rd page Rich Krause(rskrause) steped in and explained a basic "how to pick a cam"
Old Jun 13, 2003 | 12:54 AM
  #30
D James's Avatar
saint69 what timing chain are you running, I see your reving pretty high, wondering if you got the extreme and if it holds the abuse like people say? On another note I felt a difference in my low end torque with the bigger cam, it just seems like the powers not there low than all of a sudden it just comes on full force, at a fairly high RPM range. Who ever mentioned the dyno graph for Kmooks car is smart, thats a good way of seeing what your getting into, power starting up at 4 grand doesn't sound appealing to me, others its fine, I Know Saint69 has said he like the top end power for accelerating from a get go instead of a dead stop. As far as smell goes, I just put fresh cats on my duals and there was a huge smell increase standing next to my car, I didn't notice any difference inside, and my cam is a blower cam so not much overlap and thus not such bad fumes as the cc306. I will say some people love the heavy exhaust smell. I use to drive with a 3400 rpm torque converter in my daily driver, it sucked at part throttle, but sure worked well, maye because I was at full throttle more often than not, other people can't bare anything higher than 2400 RPM so you might love the cc306 or hate it, I would really suggest checking into previous posts as much as possible and anywher else you can find info on the different cams cause its a lot of work and money to just jump into. If you have decided you might want to try this deal which ends this Friday, its a great deal, they can help you on what will be best. http://web.camaross.com/forums/showt...hreadid=129985 Have you any goals in mind on what you will ultimately will want--heads/cam nitrous/supercharger?
