Is a XE 230/236 "too big" for non-ported heads?
I have the Torque converter, Programming, Headers, 3.73 Gears, and E.T. Streets to back it up. Its just my heads are not ported. Click on my sig for any thing you may want to check on. Just looking to put a cam in after I had some bad experiences last Wednesday with my Bolt-ons. Do you think the XE 230/236 112 LSA will work alright, or should I get the 224/230 cam? Thoughts?
I honestly thing its too big
the cam makes power uptop and not down low which isn't a bid deal for you b/c u have a converter.
the heads cant supply the air at such high r's
I think 224/230 is a great cam. it should rev upto 6400-6500 with heads anyway. I wouldn't want my stock bottom end revving higher than that anyway
plus it will match your stall better than the 230/236 anyway
Well normally i would say it is a little to much cam but lately there have been a few guys on here that have installed fairly aggressive cams in their cars and seem to love the power band so it is really up to you.Do you want to rpm your engine to 6500 or 6000.If you don't mind going to 6500 which isn't that high then i would say go with that cam.
Originally posted by ucrazymonkey
No, I really dont want to have to take it above 6000 RPMS. Right now my car shifts at 5900 RPM.
Victor Lamb
Aug 26, 2017 02:52 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
