XE 230-236 Clearance?
Old Feb 9, 2003 | 10:48 PM
Mr. T's Z's Avatar
I did a search and found some info. I will have stage 2 P&P heads with my 230 236 and have the double valve springs. Will the 1.6 rockers clear?
Thanks,
Tyler
Old Feb 10, 2003 | 07:55 AM
Mr. T's Z's Avatar
Also who knows the lift with the 1.6?
Thanks,
Tyler
Old Feb 10, 2003 | 08:09 AM
CARGASM's Avatar
it all depends on which 230/236 you have.
Go here!
Old Feb 10, 2003 | 09:48 AM
Gripenfelter's Avatar
Your lift will be .544/.555
As long as you didn't mill the heads more than the usual amount you should be fine.
Old Feb 10, 2003 | 09:52 AM
Mr. T's Z's Avatar
THANKS!!!! Few you guys are always a LIFE SAVER!!!!!
Tyler
Old Feb 10, 2003 | 10:27 AM
'94 Bad A Z28's Avatar
Tyler!!! I didn't see this post untill now... Sorry, lol... The 230/236, that's what cam you are going with?! I was thinking you were going with something like the 236/242 or bigger from the way James talked about how "huge" your cam was, lol.
Old Feb 10, 2003 | 11:15 AM
97Z-M6's Avatar
http://www.cmotorsports.com/lt1customcamshafts.htm has the xe236 listed as a 236/244 i thought it was a 236/242 not 244, or is it just because its a custom grind.
what is the most lift peole are able to run on non milled heads and the factory heads gaskets. has anyone attempted over a .600 lift with succsess.
Old Feb 10, 2003 | 11:20 AM
stik6shift93's Avatar
94 bad a z28, I to was thinking of going with the 236-242 instead of the 230-236. I won't be getting it done until mid summer, if you get it done first let us know how it goes.
Old Feb 10, 2003 | 11:28 AM
I was just saying that is what I thought he was going with, lol.
But I do plan on doing a heads and cam package... And it will be the XE 236/242. So when the ordering starts, I'll let y'all know!
Old Feb 10, 2003 | 07:58 PM
97Z-M6's Avatar
ttt
Old Feb 10, 2003 | 08:11 PM
NiteRider's Avatar
I'm going with the cam also, should be here soon better make some good power!!
Old Feb 10, 2003 | 08:37 PM
NiteRider's Avatar
Anyone have any track time or dyno runs with this cam?
Old Feb 10, 2003 | 10:06 PM
Mr. T's Z's Avatar
Ya eddie, but there is a treat to my cam its on a 111 hehehe It will lope like a mother. They heads a BAD also. I'll let you know when I start it you can come over for sure. Hope all is well. I am taking the word that is will work with 1.6 rockers.
Thanks,
Tyler
Old Feb 10, 2003 | 11:14 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
They clear just fine... I just installed mine .. 230/236 - but the new grind w/ more lift.. on a 110LSA .
Old Feb 11, 2003 | 07:20 AM
97Z-M6's Avatar
so what is your lift on the cam with just 1.5rr
