XE 224/230 installed!!!
Old May 8, 2005 | 11:23 PM
86T/AWS6's Avatar
Well i just got done with the install, and the weeks worth of work was well worth it...the car sounds awesome, pretty lumpy at idle even when hot. I have alot of tuning ahead of me to get the cam surge out of it and richen up the top end.....Best of all the bearings are still in it and it holds 40psi of oil pressure at idle hot...
Here's the parts list:
- Comp XE 224/230 .535/.544 112LSA
- Comp "R" lifters
- CM Hardened push rods
- GM 1.6 rockers
- CM EX 612 springs/retainers
- New timing chain set
- Melling oil pump (10% over stock)
- Mallory 685 digital ignition
- MSD blaster coil
Didnt get on it yet since i still have the tune in it for the stock cam, but that will change soon...My new Gtech RR will be getting a work out....
Anyone have a good tune for this cam??? if so PM me if you could help me out...otherwise i will be using PCMforless as a base
Old May 8, 2005 | 11:34 PM
turbo_Z's Avatar
Re: XE 224/230 installed!!!
Give madwolf a shot on the tune. I have seen too many PCMforless tunes out there and you know why I can tell they are PCMforless?... its because they all look almost identical. Never seen a madwolf tune but I hear he does amazing things.
Nov 18, 2023 07:21 PM
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
1996LT1Z28
Apr 14, 2015 07:15 PM
Carogna'sZ-28
Feb 3, 2015 07:04 PM
