Xe 224 230 Dyno
Old Apr 24, 2004 | 09:08 PM
OffspringZ28's Avatar
Xe 224 230 Dyno
342 hp and 342 trq. AF was 11.4. This was with the PCMforless tune and mods in sig. i was expecting more but what are you gonna do.
Old Apr 24, 2004 | 09:20 PM
Loadre's Avatar
Thats way rich. You can pick up a good bit with a better tune.
Old Apr 24, 2004 | 11:00 PM
Lt1dtpower's Avatar
Did you do any head work.
Also if what you have listed in your sig is all of your mods then I think that your #s aren't that bad. A.F could be better.
Old Apr 25, 2004 | 12:01 AM
no head work. prolly just tell PCMforless to lean it out a bit.
Old Apr 25, 2004 | 01:37 AM
CMGETSM's Avatar
or put a bottle on it.
Old Apr 25, 2004 | 03:11 AM
Loadre's Avatar
It'll run even richer then. All kits are jetted to err on the safe side (rich).
Old Apr 25, 2004 | 06:29 AM
jkipp84's Avatar
I got 326rwhp with the 224/230 and Bryan's tune - but I have an A4. After ironing out the bugs, I'd expect to see something in the 345-350 range with an M6.
I think the numbers you've got are good, you're not too far off of what the cam is capable of plus - you know what you need to do to get there.
Old Apr 25, 2004 | 06:55 AM
tim95z28's Avatar
can you post the curve? Where was your peak hp and how high did you run it? I would think you should make power past 6k.
Old Apr 25, 2004 | 07:26 AM
RealQuick's Avatar
Re: Xe 224 230 Dyno
332 hp and 342 trq. AF was 11.4. This was with the PCMforless tune and mods in sig. i was expecting more but what are you gonna do.
I would expect around 340rwhp/350rwtq by leaning out to 12.8-13.0. I went from 10.0 to 12.8 and picked up 15rwhp/17rwtq peak, but picked up over 30rwtq from 2400-3000rpm.
Old Apr 25, 2004 | 08:24 AM
the car was revved up to 6100. The horsepower did drop at all but seemed to flatten out at around 5500. I will try to get pics up asap.
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
Strick
Jul 14, 2015 07:28 AM
