XE 224/230 or 230/236
Old Feb 2, 2004 | 09:14 PM
Black6SpdTA's Avatar
I'm building up my 350 SBC. I bought a set of LT1 heads tonight and will have them slightly ported. I'm getting an intake (LT1) this weekend and will be modifying/installing it all on my Gen 1 motor.
I'm undecided on cams. XE 224/230 or 230/236? I was leaning towards the 224. Other mods will be:
-1.6RR
-Headers
-CAI
-Proper Tune
What cam and with each, what numbers should I expect (rwhp)? Thanks.
Old Feb 2, 2004 | 09:16 PM
FacelessZ's Avatar
No point in porting your intake to 58mm if thats what you were looking at doing...
If you're going for a 'mild' port with higher mid lift numbers, I'd say go with the 224/230...
Old Feb 2, 2004 | 09:21 PM
Oh no, by modifying I meant making it compatible to a Gen 1 motor (rear mount distributor, etc).
Cool, that's what I was looking at.
Old Feb 2, 2004 | 10:55 PM
Do I understand that you are putting LT1 heads on a regular SBC? Not sure I have heard anyone doing this. Correct me if I am wrong, but modification will be needed to make it work. You will also have to use an LT1 or LT4 specific intake manifold.
If I misunderstood, then nevermind.
Old Feb 2, 2004 | 11:12 PM
MY91Y84's Avatar
it actually quite simple shoebox...you weld aluminum chunks into the front and rear ports and your good to go
Old Feb 2, 2004 | 11:27 PM
So how do the heads stay cool without all the coolant passages working?
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
LimitedEd1LE
May 18, 2015 01:24 PM
sc93
Mar 5, 2003 05:56 PM
Formula_one
Mar 2, 2003 09:40 PM
CJ Black LS1 Z28 M6
Middle Atlantic
Jan 5, 2003 10:17 AM
