x pipe for 94-97 camaro
Old May 30, 2004 | 01:13 AM
two-gunkid's Avatar
i have a question i saw on this website that this guy bought a x-pipe for his 95 camaro Z28 which would replace the y-pipe and make it a true dual exhaust. i have pic of it from his website. i want to buy a 95-96 Z28 camaro with t-tops as my first car (im 16 turning 17 in 12 days) and when i talk to my friends about car stuff they ask why the camaro was made with a y-pipe. and i want to get the camaro and make it a dual exhaust.
Old May 30, 2004 | 01:15 AM
two-gunkid's Avatar
how do i post pictures?
Old May 30, 2004 | 09:35 AM
gb95zconv's Avatar
You cant post them here....you can link to them on a host sight.
Old May 30, 2004 | 02:36 PM
Josh'95Z28conv's Avatar
If you put an x pipe and duals in there you will loose tons of ground clearance. It wont be worth it unless you have long tube headers. Then you will have little ground clearance anyway
edit: Here is a company that does duals to go along with long tubes. There are pics and vids...
http://www.lanesperformance.com/custom_duals.html
Old May 30, 2004 | 10:43 PM
two-gunkid's Avatar
the x-pipe that im talking about, looks like a y-pipe but is a x-pipe that follows the path of the y-pipe the one at the lane website is like a x-pipe for a mustang.
Old May 30, 2004 | 10:54 PM
two-gunkid's Avatar
i found the site i saw the pic at here are links below.
http://www.bfranker.badz28.com/94z/xpipe.jpg
http://www.bfranker.badz28.com/94z/xpipe2.jpg
Old May 31, 2004 | 04:34 AM
two-gunkid's Avatar
has anyone ever seen this x-pipe before and about how much ground clearance would i have left if i were to install the other x-pipes that goes under the driveshaft?
Old Jun 1, 2004 | 12:34 AM
two-gunkid's Avatar
does anyone have pics of x-pipes installed on their 93-97 camaro ?
Old Jun 1, 2004 | 01:48 AM
Koby's Avatar
Not to sure how much ground clearance you will lose with that one. I have seen pics of people who have fabbed up there own true dual system and not any ground clearance besides what the LT's already gave up.
The pic. there would be the X pipe you would need. After that just run to pipes up and over the axle with some bullet mufflers, or just slap on some bullets with turn down's and don't worry about over the axle. Either way works.
onefastgta
Mar 19, 2015 10:10 AM
MadMav
Feb 6, 2015 11:02 PM
spearous
Jan 12, 2015 11:03 AM
CaRParts102
Dec 6, 2014 08:45 AM
thenewkid
Nov 18, 2014 12:57 PM
