X or H pipe for duals which flows better ?
Old Oct 28, 2004 | 09:05 PM
RedHottG2's Avatar
What is better for a dual exhaust set up, H or X pipe ? I know they make the X pipe in either 2 1/2" or 3" but do they also make the H pipe in the same sizes ? Has anyone seen a flow difference between the two ?
Old Oct 29, 2004 | 08:26 AM
QUASARBLUEZ28's Avatar
Re: X or H pipe for duals which flows better ?
Here is some insight into this question. I have a vintage Mustang with duals w/o an X pipe or H pipe and asked the same questions on the Vintage Mustang forum.
"- and X-tubes for dual exhaust--
H-tubes balance the backpressure between the two sides of your engine, and even out the complex pressure waves that are flying around in the pipes. The result is enhanced low-end torque, better overall performance, and better sound.
Why?
With a V8, there are always two cylinders on each side of the engine that fire within 90 degrees of each other. On a small-block Chevy, the firing order is 1-8-4-3-6-5-7-2, and the cylinders are numbered from front to back down the crankshaft. Odd numbers on one side and even numbers on the other. A cylinder fires every 45 degrees of crankshaft rotation.
So by looking at the firing order, you can see that cylinders 4 and 8 fire 45 degrees apart on one side. Then later, cylinders 5 an 7 fire 45 degrees apart.
This creates a high-pressure pulse that inhibits smooth flow and makes for a "choppy" exhaust sound. H-tubes and X-pipes equalize this pressure pulse, smoothing out exhaust flow and sound, thus helping your torque output. X-pipes do a better job of this than H-pipes, because there is no distance separating the pipes with an X. But some cars, like my 'Bird, have no way to fit an X underneath.
H-tubes should be at least 3/4 the size of your exhaust pipes, and located in the "hot" area of the pipes behind the header outlets. To find that hot area, one suggestion is to spray a line of ordinary white paint down the pipes after the headers, and go for a good run. Install the H-pipe somewhere in the area where the paint burns off the pipes, equal distance from each header collector. Use the same technique to determine where to place an X-pipe. "
Hope this helps some. Performance wise the X-pipe setup is viewed as superior to the H-pipe.
Old Oct 29, 2004 | 09:09 AM
RedHottG2's Avatar
Hey helps alot!! that was exactly the kind of info. I was after.
Old Oct 29, 2004 | 09:14 AM
Red96Lt1's Avatar
Nice write up. I was just going to say that an x pipe is better.
Javi Fierros
Exhaust System
10
Apr 20, 2017 12:46 PM
R@mpage
Apr 20, 2015 10:02 AM
MadMav
Feb 6, 2015 11:02 PM
