WTF...tranny mount?
WTF...tranny mount?
i am in the process of putting in a new tranny mount...i took the old one out and now ive got the new one on...im lookin at it under the car...lining up the bar that goes across and bolts to the bottom of the car...and it looks like there is going to be a hung gap...am i supposed to just tourqe the 4 bolts down as far as i can??...HELP!!
sorry....the new tranny mount...p/n 22201140 looks like it is too "thick". I sized up the cross brace that the bolt that is stickeing out of the bottom of the mount stickes through, which the nut goes onto, and it looks like the brace will be too far away from the underside of the car, where the 4 bolts that hold it to the underside of the car go through
That mount is a little taller. It is not a problem, though. I would put some support under the trans or under your crossmember (however you decide) and move it all up until the crossmember is up next to the underside of the car. If you pull it up with the bolts, you risk stripping the threads.
thanks shoebox...i jacked up the trans and got everythig to fit in fine...god were my fingers numb. I took the car out for a drive...woohoo...no rattles....for the first 5 minutes. now it rattles at idle, and throughout the RPM range...it used to only rattle when starting out, low in 1st gear. I got back under....tried to tighten the bolts as much as i possibly good...and it still rattles. Anyone have any ideas...maybe its not the tranny mount??
I checked all the exhaust piping before i determined it was a tranny mount the 1st time...i dont think its them...but it never hurts to double check. As for the rattling, it sounds like it is coming from behind the drivers seat, and sometimes i can feel it when my foot is of the clutch through the floor. Anyone else have any ideas?
Originally posted by 2CNTRY
So it was the tranny mount the first time and now it isn't? Check the piping again. Another possibility is the pipe clamps are loose. But you probably checked that as well. Can't think of what else but something related to the exhaust. If it rattles during idle then I don't see why you shouldn't be able to look under during idle and isolate the location.
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
