WS6 airbox conversion, where to run opti vent?
Old Mar 8, 2005 | 05:23 PM
Birdman7389's Avatar
On my '97, just put a WS6 hood and airbox, and did not find anywhere convenient to run the Opti vent line. Should I just drill a small hole in the box or reducer? Will it make a difference if it is before or after the MAF?
Old Mar 8, 2005 | 07:42 PM
OBE1 95Z28's Avatar
Re: WS6 airbox conversion, where to run opti vent?
Opti feed line needs to be after the MAF, as this air will be sucked into the intake manifold after it passes through the opti (otherwise it would be unmetered air causing your motor to want to run lean).
Old Mar 8, 2005 | 08:04 PM
TransAm9585's Avatar
I drilled a small hole for the line to go into the box. Havent had a problem since.
Old Mar 8, 2005 | 08:07 PM
Kataklysm's Avatar
My car came from SLP with it in the box...theres a rubber nub coming off the left side (if facing away from car) of the box and it goes into the nub.
Old Mar 8, 2005 | 08:58 PM
Sounds good. I'm pretty sure my box does not have the nub/plug so I will just make a small hole.
Thanks guys!
Old Mar 8, 2005 | 09:16 PM
ShawnMacAnanny's Avatar
That nub plug is for either the AIR or the IAT. The Opti vent line is right on the intake boot.
Old Mar 8, 2005 | 10:01 PM
My SLP air box did not have any holes except the one for the IAT sensor on the right side, and one for the AIR pump air supply on the other. Since I don't run an MAF, I found a plastic vacuum connector that fit into the Opti air supply hose, a rubber grommet that matched (snug) the diameter of the plastic vacuum connector, drilled a hole in the airbox next to the AIR connection for the grommet to fit correctly, and plugged the hose in there:
http://cjcfo.fbody.com/members/injun.../DCP03742a.jpg
Technically, as pointed out above, it should be located after the MAF. Putting it in the airbox is like creating a small vacuum leak. Nothing the long term fuel corrections can't adjust for. An alternative to the stock "bellows" that comes with the WS6 or SLP airbox is the $5 Fernco sewer pipe connector. Drill a hole in it toward the bottom (the connector is fairly thick) and push the blue elbow in there, out of sight. This is the Fernco connector, a good idea for an ram air setup:
http://cjcfo.fbody.com/members/injun...os/IntakeTrack
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
formula218
Dec 2, 2014 04:27 PM
