wrong stroker kit
wrong stroker kit
First off, let me say the engine is running good, just not perfect.I feel a VERY slight vibration at idle, but no funny noises and the car is not shaking.
Something has been bothering me about this engine since I bought it but wasn't until after wards I realized what it is. Come to figure out the rotating assembly is an external balance setup. They welded on the dampner to get it to balance. This is ugly and since I do not know the shop personaly(bought used), who knows who well it was done.. I was wondering if anybody could point me in the right direction to correct with this without having to remove engine. and take it apart and buy a new rotating assembly.
Can I just buy a fluid dampner and put it on there and all will be well? I realize that the flywheel is part of the balance as well.
Well, it was balanced. And the car runs good. It is more a cosmetic thing than anything. It looks like jeg leg balancing,but it works. I was just wondering if I got a fluid balancer if it would work cause it would look a lot better. And I know it is not easily visible to the rest of the world, but I will know. If it is the case that I would have to tear everything apart again, then I will leave it alone. I don't want to break something for the sake of apperances and just throw it on there and see what happens, So I thought I would ask.
At this point, if the had to "weld on the damper", its too late to go changing things "externally". How much weight did they add to the damper? Where did they add it? The damper is set up to counter the harmonic rotational vibrations in the crankshaft. If they "unbalanced" the damper, there's a good chance it is no longer serving its intended purpose, and may be hurting the crank more than it is helping it.
I thought the LT1 was internal balance assembly with the weight on the flywheel being a small amount?
If I am wrong, I have a stock balancer, brand new with no weight welded on it, should I try it and see what it does?
Also to answer your question about how much they welded on the front, it is pretty sold mig about 1/2 wide and 3 inches long. Seems like a lot and putting one of my stock dampner's on there probably won't help but thought I would ask.
Right, so from what I was getting from Injuneer's post was that the way the dampner is now with all the weld on it, might be doing more harm than good. So my thought was to try going back to stock with no weld on it and seeing what that would do.
Brings up a question before I try this though...If I start the car and I am wrong about the stock dampner working, it will be way out of balance based on the amount of weld on there......is the likely hood pretty good that something will break? Or atleast mar something on the rotating assembly? If that is a pretty good chance, I may just drive it as is. The vibration is only for 500 rpm and I sent an email to previous owner and he said he never felt it. Now I know better than to trust everyone you buy things from, but it leads me to believe something else is the cause of my annoyance, I just thought this was a logical blace to start.
If you take it off then make sure you can get it back on in the same position in case it isn't keyed on the crankshaft like the stock ones. matter of fact, if they didnt key it, then it can possibly spin and cause a problem that way. The flywheel weight would be less than what is on the damper cause the weight is further from the center of rotation. Too bad they set it up this way, sounds like a mess.
If they welded a weight to the stock balancer I'llbet that that is their balancing job. Ask the shop that did it, it helps to communicate a little. If it's there to balance the motor then youre gonna have to use it unless you yank the motor and get it balanced with stock pieces.
Drtryder
Apr 22, 2015 04:17 PM
