The wrap up... "Project Daily Driver" guess the hp/tq numbers...
As things come to a final close in the coming 48 hours... It is time to do a wrap up.
18 months ago I began a project... not suppost to be a project... but more of a reliability check for my car. About 2 months into it... is when we changed pace and began what is now commonly called "Project Daily Driver".
I never realized how much money, frustration, or fame this would cause. I have spent well over $14K. Literally hundreds of hours on the phone... hundreds of emails, pm's, misordered parts, searching, research, everything. I receive emails and phone calls on a weekly basis from different companies across the nation asking how its coming, if its running, some dyno numbers, ect. I never realized what this would bring. Along with all the flaming from the local guys... lol. I want to put out some much needed thanks to those of you who have bent over backwards through these past 18 months...
First and foremost... my grandparents for providing me this opportunity to make a dream come true in the first place... owning a 1997 30th Anniversary Camaro.
Carolina Speed Shop (CSS www.carolinass.com) There arent enough thanks that can go out to Kyle, Carmen, Brandon, and Johnny there. It truely would have never been a possibility with out them. Much thanks to Kyle and Carmen for taking care of the car while I was deployed, and when I could not be around to move the vehicle for them, and for providing me a place to work and stay during some rough times and late nights... you guys are truely the best friends someone could have.
JDs Performance
Elliot's Portworks (Lloyd Elliott) Possibly saved my new motor
Victory Racing
Single Digit Racing
Here is a wrap up of the engine......
LT1 block bored .030 over
Forged 16CC Dished JE Pistons
Forged Eagle Connecting Rods
Forged 4340 Eagle Crank
ARP Bolts
High Flow oil pump/pick up
Canton Racing 7qt Oil Pan
Custom Grind Comp Cam (2XX/2XX .6XX/.6XX 112 LSA)
Morel Drop in Lifters
Double Roller Timimg Chain
LE3 Heads...
Ferrea 2.05/1.60 valves
PSI dbl springs
160 lbs on seat
400 lbs open
Ti retainers
10 degree locks
57 cc chambers
Flow #'s . . . . .
.2 144/108
.3 201/143
.4 245/176
.5 272/189
.6 283/197
.650 287/202
ARP Head Studs
1.6 Comp Pro Mag NSA Rockers
LT1 Intake Ported
BBK 58 MM Throttle Body
1LE Intake Elbow
FPIK K&N CAI
Meziere Heavy Duty Water Pump
New GM Vented Opti
Built 4L60E from CSS
3600 Lock up converter
Any guesses to hp/tq numbers???
JDs Performance
Victory Racing
Single Digit Racing
ARP Bolts
LE3 Heads...
PSI dbl springs
160 lbs on seat
400 lbs open
Ti retainers
10 degree locks
57 cc chambers
Flow #'s . . . . .
.2 144/108
.3 201/143
.4 245/176
.5 272/189
.6 283/197
.650 287/202
ARP Head Studs
LT1 Intake Ported
1LE Intake Elbow
FPIK K&N CAI
New GM Vented Opti
Re: The wrap up... "Project Daily Driver" guess the hp/tq numbers...
I'm gonna say close to 425 to the wheels...i have almost the same setup...just putting the final fine tuning touches on mine...i'm hoping for 410 to the ground...
carguyshu
Jan 22, 2017 11:19 AM
Sergio
Jan 27, 2016 04:27 PM
NewsBot
May 19, 2015 09:30 AM
ksharr
Aug 30, 2002 10:58 AM
