Would it be worth it for me to switch to the R lifters?
Old Jun 19, 2003 | 12:53 AM
thewinner's Avatar
Hey guys
Building this 383 with a 200shot or so of juice. cam will be 230/236/112 .544.555 or a 230/242/112 .544/.578
right now i have stock lifters sitting in a box. However, due to all the metal that was in the motor, im pretty sure they are just filled with metal shavings gotta check em out tomorrow. so i was looking to get the comp r lifters.
what are the advantages of these., and what does anti pump up mean?
Also I have heard that some people have had problems with their R lifters? Any stories?
Lastly is there any break in required for a lifter? like soaking it in oil?
Old Jun 19, 2003 | 08:23 AM
thewinner's Avatar
ttt
Old Jun 19, 2003 | 09:14 AM
sssalah's Avatar
The comp r lifters are discontinued for more than a year.
Old Jun 19, 2003 | 09:52 AM
94SLUG's Avatar
I also heard they last 10-15k max. New stockers or cranes will be fine.
Old Jun 19, 2003 | 12:31 PM
thewinner's Avatar
lol where have you been the past couple months, the R lifters are back
More opinions needed.
Old Jun 19, 2003 | 12:37 PM
thewinner's Avatar
15k miles max.....hmmm for some reason i doubt that, or there would be alot of pissed off people. Any one who actually has these lifters with opinions?
PS: How do you clean lifters out?
Old Jun 19, 2003 | 02:52 PM
Buttercup's Avatar
All of the lifters are made at only a few factories in the world. Crane lifters came from the same place as the CompCams lifters or even the GM lifters. This is why, for a while, there were no aftermarket lifters available. One of the factories had problems (burned down???) and the OEM's were using all the available lifters on the market leaving the aftermarket companies with nothing. The lifter bodies, plungers, rollers, etc. are all identical and if installed properly the 'R' lifters should last as long as any other.
The cavity between the lifter bodies and plunger fill with oil, this is what makes the hydraulic lifters self adjusting. Oil flow in and out of the body is controlled by orifices and tight tolerances. The problem with hydraulic lifters and high RPM is that more oil can enter into the lifter than is bled out. The lifter than "pumps up", the results are the same as an overly tight lashed rockers, the valves hang open. The opposite can also happen on a worn lifter, more oil bleeds off than the lifter is supplied with and the lifter "collapsing" which results in a condition similar to excessively loose lash.
It is possible to clean your own lifters as well. To disassemble the lifter you simply need to remove the locks and retainers from the top, clean and inspect, and reassemble with new locks. Never having done this I don't know what kind of advice I can give The tolerances on the lifters are VERY tight and if much foreign material has entered into the lifter body you may have some lifters that will collapse under spring load.
The main difference between regular and the 'R' lifters is the retainer and locks used by CompCams. For this reason the plunger is set deeper with the 'R' lifters. Because of this you should lash the 'R' lifters *just* past zero lash and no further.
Old Jun 19, 2003 | 03:02 PM
thewinner's Avatar
stock lifters are almost as much as the comp r right? at least the comp oem replacements are.
Guess the saying better safe than sorry applies here....
Old Jun 19, 2003 | 03:35 PM
thewinner's Avatar
im gonna buy a set of the R lifters. dont feel comfortable attempting to clean those, and expecially putting those back the car!
Old Jun 19, 2003 | 03:42 PM
Buttercup's Avatar
I'd probably do the same thing, it may save you more time and money in the long run. Depending on where you buy them, the lifters should all be similar in price for the reasons I mentioned above (they are basically all the same!). Just keep in mind what I said about lashing the 'R' lifters. I'm lashing mine at about 1/8 turn past zero lash. I wouldn't go above 1/4 turn, if that.
Old Jun 19, 2003 | 04:20 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
last 15k miles? where did this come from?
prorobly somoene who cant adjust their valvetrain.
Aren't Comp R's rapid bleed down?
If they are, i wonder if low rpm cruising for exteneded time (ie 500mile trip at 65mph in 6th gear with 3.42s) would hurt it..
i highly doubt it though..
Comp R's are like $20 more and definatly a good think IMHO. I got them. I hope they fare me well
Old Jun 19, 2003 | 04:38 PM
Buttercup's Avatar
They are not rapid bleed down. You might be thinking of the lifters that bleed down so fast that they make very large cams livable at low rpm but "pump-up" at high rpm taking advantage of the large cam.... kind of like a simple VTEC I've been running 'R' lifters for some time now with zero problems
Just keep the lash down and all should be well.
Old Jun 19, 2003 | 04:55 PM
thewinner's Avatar
fawk 3400 in debt now
So once zero lash is found, just a hair past it? Do they come with the instructions that tell that?
Old Jun 19, 2003 | 05:00 PM
treyZ28's Avatar
Does anyone make rapid bleed downs for us?
Old Jun 19, 2003 | 05:06 PM
Buttercup's Avatar
No instructions but I can tell you there's been a few people that treated them as "regular" lifters and had problems.
What I normally do is find zero lash, then tighten the poly lock with an allen wrench so it just starts to snug up, I then use a wrench to turn the whole assembly as tight as I can. This should give you ~1/8 turn past and positively locks the rocker in place.
I'm not sure if anyone makes that style for roller lifters. Regardless, a lot of the pros feel they are more gimmick than they are effective.
