would this work on stock lt1 heads
Old Jun 4, 2009 | 08:11 PM
hughett17's Avatar
Question would this work on stock lt1 heads
im lookin to upgrade the valve train on my stock heads to get ready for the gm 847 cam and was wondering if these springs would work im on a very very tight budget due to having to relocate to a new job but im still trying to get my valve train in order to run the car till i can get a better set of heads thanks
http://www.jegs.com/i/Lunati/638/73943K1/10002/-1#
Old Jun 5, 2009 | 01:31 AM
JAKEJR's Avatar
Sorry, there's no way for me to know. I couldn't find any of the specs on those springs.
UPDATE: I went back and double checked and I found the specs. Just as posted by Airborne.
Jake
West Point ROCKS!
Old Jun 5, 2009 | 01:46 AM
MachinistOne's Avatar
Not enough spring pressure with those. I don't know of anything that will work in that price range - the parts I use add up to about $250 for the mild street setups.
Old Jun 5, 2009 | 09:48 AM
RamAir95TA's Avatar
Do yourself a favor and do NOT skimp on valvetrain components. If you're on a very very tight budget, save a bit longer for a reputable valve spring and hardware.
Old Jun 6, 2009 | 04:23 PM
NightTrain66's Avatar
what cam are you trying to use them with?
I would not use that set up at all but I can probably steer you in the right direction on what sprinsg will work at a good price.
Lloyd
Old Jun 6, 2009 | 05:31 PM
Airbornec507's Avatar
638-73943
Single w/Damper
1.266'' Diameter
.883 I.D.
1.750 Installed Height
Seat Pressure: 108lbs
1.250 Open Height
Open Pressure: 339lbs
Coil Bind 1.060''
Max Lift .630''
Rate 462 lbs/in
Retainers
638-75707
Chromeoly Steel 7°
Locks
638-77003
11/32''
Single Groove
Heatreated Steel
Works with Lunati Cams 00010, 00011, 00012, 00013, 00016, 00017, 00018, 01001, 01002, 01003, 01005, 06100, 06101, 06102, 06103, 06105, 06106, 06107, 06108, 06109, 07101, 07102, 07103, 07104, 30110, 30111, 30113, 80350, 90350, 60100, 60101, 60102, 60103, 60104, 60105
As listed above.....doesn't look like nearly enough seat presure to control a more aggressive lobe. I'd stay far away from those. Just my .02.
Lots of folks are favoring the Patriot "Gold Extreme" kit now days that comes with everything and can handle most cam grinds out there (hear-say).
birdblack
Dec 30, 2014 06:59 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
Brian-94TA
Jul 31, 2002 02:52 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
