would stock springs work for cc305?
Old Feb 20, 2004 | 11:41 AM
tanker's Avatar
My brother finally decided to mod his 96 B4C camaro z-28, m6. He is on a limited budget, so first we got a used cc305 cam cheap and I was wondering if it's safe to install it without changing the springs. We are keeping stock rockers for right now.
I know cc 612 springs would be perfect, but they are $110 at combination motorsports, and adding seals this would go over his budget
Old Feb 20, 2004 | 11:42 AM
hot_red_z28's Avatar
I would highly recommend getting new springs. They may not be ABSOLUTELY necessary, but if one binds up and he trashes a valve, he'll be WAY over budget...
just my $0.02...
Old Feb 20, 2004 | 11:48 AM
tanker's Avatar
OK, I guess my brother will have to pospone his weekend drinking for a couple weekends and go sell more pizzas to make some money for springs
BTW, what you guys think about comp cams 612 springs, read that they are good up to 580 lift, and cost $110 with lock and retainers. Any cheaper alternative?
Old Feb 20, 2004 | 12:16 PM
brandboZ28's Avatar
I have those springs and if Im not mistaken, they are good to a .600 lift. The EX-612's??? Anyways, they are about as good of a deal as I found for springs dealing with higher lift without having to machine the heads for seats. Its worth it IMO. Also, changing the valve stem seals isnt a must, its smart though, especially since you will already have the springs off.
Old Feb 20, 2004 | 12:18 PM
Red96Lt1's Avatar
Get some new springs.
Old Feb 20, 2004 | 12:30 PM
lt1g3n's Avatar
i just bought the same cam, and here are the springs that they recommended to use for it :
www.summitracing.com -- in search for part #, type in :
CCA-983-16
They cost $69.69 , and will support that camshaft.
Still a bit -o- money, but cheaper than what you were looking at..
Old Feb 20, 2004 | 12:31 PM
lt1g3n's Avatar
just re-read your post.. if it comes with the locks and retainers etc... then i think that's a pretty good deal...
Old Feb 20, 2004 | 12:32 PM
tanker's Avatar
Yes, I was referring to EX-612-16 springs on combination motorsports, but there is no max lift number, I guess I will have to call them
Weird, I thought there would be somebody cheap enough to use stock springs with aftermarket cam, but I guess I was wrong. I though that I needed new springs for my brother, but since head porter did all the work on my car, I will still have to learn how to do it.
Where could I get valve stem seals? Whichis the best brand?
Thanks guys
Old Feb 20, 2004 | 01:17 PM
95 Silver TA's Avatar
If he is using the 1.5 Rocker or 1.5 Roller Rockers. He can do what I did, just get some Lt4 Spring for 35 bucks. The CC305 is rated at .510/.510 Intake and Exhaust side with 1.5 RR and the LT4 springs are rated at .525 Lift and are a lot cheaper to. They also come with everything you need too. I have been running the CC305 with 1.5R and the Lt4 springs for over 24K miles with no problems at all. I cant remember the actually website but I got mine from Scog & Dickie Performance (sp) or you may want to try Jason Cromer at http://www.samtaylor.com/html/parts.html
Its a much cheaper alternative that will work Very Well with 1.5RR.
Thx,
Claude
Old Feb 20, 2004 | 01:23 PM
SVT Killer LV's Avatar
Thx,
Claude
Claude you bring up a very valid point, the hotcam springs will work perfectly.
oldschool
Feb 9, 2016 09:21 PM
Catmaigne
Dec 25, 2014 12:16 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
