Would a leak like this cause a problem?
Old May 1, 2004 | 08:35 AM
Cmr0z28's Avatar
On my Pacesetter LT's, the collectors leak a little, and they are about 4 inches after the O2 sensors. Would this be causing my problems?
Old May 1, 2004 | 08:40 AM
LT1ponykilla's Avatar
I would say any exhaust leak could hurt some. Dont know how much but its not good. I had a blown gasket where my collector on my shorty headers and y pipe bolt up and it sounded horrible. Sounding like metal on metal grinding. Felt like I also picked up a little bit of power when I replaced it.
Old May 1, 2004 | 08:46 AM
Cmr0z28's Avatar
There's the problem, I don't have collector gaskets. It's all a slip-fit design, and I can't bend it to make it fit right.
Old May 1, 2004 | 09:41 AM
Get some gaskets and you should be ok.
Old May 1, 2004 | 09:44 AM
Cmr0z28's Avatar
I can't use gaskets.....my exhaust uses slip-fits and band clamps.
Old May 1, 2004 | 09:47 AM
Is this true with all Pace Setter long tubes? I sure hope not cause Im going with those long tubes and dont want any leaks.
Old May 1, 2004 | 09:48 AM
Cmr0z28's Avatar
Every car is different. It's not the design that leaks, it's just that the Y-pipe didn't happen to fit that great on my car.
Old May 1, 2004 | 09:50 AM
Rich_z28's Avatar
You might lose a tad bit of power, but nothing to be concerned about. Since it's after the O2's, it's not that big of a deal.
If you're having a problem with the slip on collectors leaking weld them on.
Old May 1, 2004 | 09:52 AM
Well, Im going with the x pipe and true duals. So... maybe I wont have this problem.
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
ChrisFrez
Feb 22, 2015 08:47 AM
alex5366
Feb 17, 2015 10:43 PM
artic94
Jan 17, 2015 11:19 AM
