Would I benefit from an LT4 Knock Module?
If you have a loud exhaust and or aftermarket roller rockers or if you're engine is old and "loose" and makes a little more valvetrain noise than it used to, the LT4 KM will add some hp as it won't retard the timing like the LT1 unit will.
Jason
Jason
I think it's a nice piece. I have the dual Bullets w/ x pipe so my car shakes A LOT and has a good bit of vibration. Plus I have headers, so I thought it would be a good investment to get the KM. Couldn't hurt.
I just picked up 10RWHP and 8TQ with it on an otherwise stock LT4 motor:
http://www.lt1.net/dyno.htm
If you have roller rockers, anything done to the exhaust or more significant mods (cam), then it is Definitely worth it. As to desensetizing the KM, why? Try the LT4 KM first, if you still see false knock then worry about finding another way to fix it. I'd guess though, that 90% of the time the LT4 KM will solve all false knock issues.
The module is located in the ECM. Take it out, flip it over and there is a little cover with two screws that it is located under. You don't even need to disconnect the ECM harness or the battery to replace it.
As to cost, mid $20 range available from a number of sources. Check the other thread:
http://web.camaross.com/forums/showt...hreadid=228440
