would this give me problems?
Old May 19, 2010 | 07:51 PM
  #16
byrons1502's Avatar
Vacuum leak is possible or a crack in the air intake tube or bad vacuum hose/connection. That will cause a maf code. What brand of plug wires/wires did u use
Old May 19, 2010 | 08:04 PM
  #17
dangalla's Avatar
what exact code do you have?
although you might have a vacuum leak i doubt it is the cause of your drivability issues
was there any other work done to this car before this issue arose. what type of plugs and wires did you use
Old May 19, 2010 | 08:10 PM
  #18
byrons1502's Avatar
i agree that a vacuum leak is not likely your problem. Replacing plugs and wires is a must. You need to put on the best parts available. Anything from autozone or advance should be avoided. I recommend A/C delco plugs and delco,napa belden premium,taylor. I fix alot of problems by replacing NEW parts from autozone with quality parts. You need to get at least the plugs changed and start there
Old May 20, 2010 | 02:18 AM
  #19
Skullified's Avatar
I used ac delco plugs the nice like 7 dollars ones. As for the plug wires I'm not sure I know they cost about 55 bucks. I replaced the intake elbow like 2 or 3 months ago. No engine work has been done to the car. It ran great for 5 months before it started missing. Why would my intake manifold have lower than normal pressure? And I will try looking for receipts for the wires but my friend who helped me install it has no idea either.
Old May 20, 2010 | 02:20 AM
  #20
Skullified's Avatar
oh and I don't know the exact code i have as they only told me i had MAF problems
Old May 20, 2010 | 09:10 AM
  #21
byrons1502's Avatar
go to autozone or advance and get the codes pulled again and repost for us. a manufactured specific code would be awesome
Old May 20, 2010 | 03:27 PM
  #22
Skullified's Avatar
alright I'm sure this shop is going to love seeing me again lol
Old May 20, 2010 | 04:51 PM
  #23
Skullified's Avatar
Don't know if I said this or not but its a completly random missfire. I drove to the shop and it was fine and even on the way back it missfired maybe once. Some times its hard to drive without being embarrassed haha. It does it hot or cold and in any gear
Old May 20, 2010 | 07:45 PM
  #24
byrons1502's Avatar
On the misfire a quick check might be take a bottle of water(old 409 bottle or similiar) and spray the wires at night in the dark and see if it sparks. Thats an easy cheap plug wire test(could still be bad) Intermittant would lean me away from plugs and wires though.
Old May 20, 2010 | 08:25 PM
  #25
Skullified's Avatar
had the shop spray the plugs yesterday he said they are good and he did the carb cleaner on the intake manifold for leaks it was good
Old May 21, 2010 | 12:16 PM
  #26
Skullified's Avatar
update before i get codes scanned again. I about had a heart attack today haha. I pulled it into the garage started it with the garage door open of course. I went inside to find my camera so I could take a video of what is was doing of course I couldn't find it, but when I came back out i heard a noise. Sound like a dent was either being put it or taken out just a metal popping noise. Then after it did it 2 or 3 times damn thing backfired louder than when it backfires when I drive. I could of swore it came from underneath the middle of the car. I could be wrong though. This is the 3rd time it has happened. Why would it do that at idle?
Old May 22, 2010 | 11:31 AM
  #27
Skullified's Avatar
anyone?
Old May 22, 2010 | 06:53 PM
  #28
byrons1502's Avatar
It sounds like it possible sticking valve or valve spring but i am drawing at straws there.that could cause all the symptoms
Old May 25, 2010 | 08:38 PM
  #29
Skullified's Avatar
I put some seafoam in the gas tank today and ran it like 5 miles and since then it has not backfired once i think possibly the backfire was cuz it has sat for months at a time but it did still miss a couple of times I'll know tomorrow if it for sure stopped the backfire and ill look at my vacuum lines tomorrow as well as try to get it scanned again for the specific code number
Old May 26, 2010 | 12:27 AM
  #30
Skullified's Avatar
ok so i drove it just now and no backfire right i mean i drove it a good 8 miles just driving it nice and easy and a little bit of fast acceleration but not WOT. RPM gauge was not jumping and I couldn't tell if it was missing but it didn't seem like it was at all because it ran so smooth. I got to a stop light reved up to 3k dumped the clutch and took of sqealed 1st gear and let up at like 50 mph. Right after that the RPM guage started to jump again and it started to miss pretty badly. Is this a sign of a vacuum leak or intake leak of some sort. Only reason i felt this may be important is because it ran fine for almost 20 miles and then suddenly when i punch it the car starts to miss and rpms jump around.
warmeck
Mar 22, 2015 06:43 PM
DetroitZ28
Feb 13, 2015 07:33 AM
karnykamaro
Feb 2, 2015 01:37 PM
NewsBot
Jan 21, 2015 04:00 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
